P0390 Camshaft Position Sensor Trouble
Posted 11 April 2014 - 09:04 PM
Posted 11 April 2014 - 09:09 PM
http://engine-codes.com/p0390.html
chances are the sensor is broken, the sensor can also be tested if you can get to the wiring plug on the front of the motor near the main drive pulley.
If anybody has fiddled with the front of the motor lately the ring on the pulley could be damaged
Posted 11 April 2014 - 09:14 PM
Just noticed the age of the car, have you had any trouble starting it?
like slow cranking or just cranking over
Posted 11 April 2014 - 09:41 PM
any more info?
flat battery ?
washed the bay?
tuned?
timing belt done ?
does it start ?
does it idle?
does it rev?
0415 522 512
Posted 12 April 2014 - 07:33 AM
