how do i install a steering wheel without cruise control, into a car with cruise control
15 replies to this topic
#1 TittySprinklez
TittySprinklez
  • 357 posts
  • Interests:spending all the coin on the rex
Posted 24 July 2014 - 02:46 PM
hi
i bought a momo steering wheel and it dosen't have cruise control, (probs should of mentioned i needed cruise control when i bought it haha) how do i install it into my gen 3 RX lib ?
the airbag plug is different, and im not entirely sure where to mount the cruise control module out of the old steering wheel :/
any help would be greatly appreciated,
cheers
luke
#2 Barbbachello
Barbbachello
    Touring Bruce
  • 6,455 posts
  • Interests:Docking
Posted 24 July 2014 - 03:56 PM
I didn't have an airbag so I just had to mount the stalk in the new wheel. There will most likely be holes or indications of where it goes. Just open up both the wheels and compare.
#3 TittySprinklez
TittySprinklez
  • 357 posts
Posted 24 July 2014 - 09:51 PM
had a closer look and took some pics for you guys,
the momo wheel has like a bracket there which im assuming activates the horn when the copper bits come together, the old wheel has none of those brackets
any ideas on what i do here?
also the plugs for the airbag are different, is it safe to be cutting and soldering wires regarding an air bag?
thanks heaps
luke
also sorry for the double post on this thread
#4 Barbbachello
Barbbachello
    Touring Bruce
  • 6,455 posts
  • Interests:Docking
Posted 24 July 2014 - 10:06 PM
Here's a pic of what I did.
8fFvJwJ.jpgI removed the right hand brackety thing then cut out the section under Neath and screwed my bracket into the plastic. Its not ideal as there are now holes in the back but you can't see them when installed. Do not cut or solder the airbag wires. You'll introduce resistance which could delay the airbag. There probably is a right way to rewire it but its not soldering. Hope that helps
#5 Guest_KONG_*
Posted 24 July 2014 - 10:11 PM
You can't cut the airbag wires dude.
#6 TittySprinklez
TittySprinklez
  • 357 posts
Posted 24 July 2014 - 10:14 PM
nah i didn't feel right about those airbag wires so i havent touched em yet lol,
cheers barb ill give it a shot, do i just make a hole for the cruise control stalk in the side of the back cover?
wait, dont you need both bracket thingys to make the horn work?
#7 Barbbachello
Barbbachello
    Touring Bruce
  • 6,455 posts
  • Interests:Docking
Posted 24 July 2014 - 10:20 PM
I only had it out to get the stalk in. For the stalk I was able to see the outline of where its meant to be on the actual wheel.
#8 duncanm
duncanm
    wha' who ?
  • 2,009 posts
Posted 25 July 2014 - 07:56 AM
can you swap over the airbag modules (the circular bangy-bangy bit) ?
The four bolt arrangement looks the same from this distance.
#9 CRUISN
Posted 25 July 2014 - 09:42 AM
Its just two wires. No different from joining any other wires if done correctly, ie soldered and heatshrinked. The connection would outlast the car.
#10 Guest_KONG_*
Posted 25 July 2014 - 12:39 PM
Looked into it and yes you can.
Here's a bit of info that may help....  http://www.autospeed...epairs&A=112205
#11 Tim.
Tim.
  • 2,024 posts
Posted 29 July 2014 - 01:45 PM
Yes it is just two wires that you can solder and i'd be confident in resoldering them, but it's not something I would take a gamble on. I would imagine every join would add resistance to the circuit which SRS don't like.
Safety system, lives at risk, void insurance claims, yada yada yada
#12 Guest_KONG_*
Posted 29 July 2014 - 07:10 PM
Yeah i'd prefer not to go there myself.
#13 TittySprinklez
TittySprinklez
  • 357 posts
Posted 29 July 2014 - 07:16 PM
would i be better selling this one and getting one more suited?
#14 Guest_KONG_*
Posted 29 July 2014 - 07:33 PM
You should be fine as long as you connect the wires correctly.
If not........
#15 TittySprinklez
TittySprinklez
  • 357 posts
Posted 29 July 2014 - 07:37 PM
hmmmmmmmmmmmmmmmm.......
what momo wheels would be a direct fit do you know? im getting the blue B4 interior so would the blue momo wheel work do you know?
i mean i have faith in my soldering, but yea, insurance and such isnt something i thought about before it was brought up :/
#16 benny_84
benny_84
  • 7 posts
  • Interests:Music , subys and skylines.
    -- 2000 GC8 WRX Impreza Auto --
Posted 02 November 2015 - 11:16 AM
my old 96 gx never had airbags so i removed the detonator from wheel and gave it to subaru ipswich, used the stalk and wires from the old wheel and added it to the momo ( similar to what y'all did here ) . bit of dremeling on the side so the stalk moved like it should and didnt jam/hit anything and she all works fine . ( and i know most won't want to cut plastic away and try poke it thru the back  , but mine was already scratched and old so i didn't mind )
