I think my fuel regulator isent keeping pressure over night? cold starts are as if there is fuel starvation and takes time to crank it over, even after priming several times before start. But starts fine on second attempt.
Can a vacuum leak be causing this?
if not regulator or fuel system can it possibly be the temp sensor doing this?
Fuel pump and filter have all be replaced.
