Negitive Boost Tank - DAMAGED
BOOST TANK
11 replies to this topic
#1 L A R V E N
L A R V E N
  • 20 posts
  • Interests:Skating, Snowboading, Subaru, BE5
Posted 30 October 2011 - 04:19 PM
Hey All,
So I had a accident (First time ever). My left hand front fender took a side impact (no one was hurt thank god).... my car is fine, the damage was only a bent fender. After all the paper work and everything I drove off. I parked the car and then sat there and the engine started dying. Lumpy idel.
Went around the front OF the car and realized my boost tank saved my front end. explaining the lumpy idol it took the full hit and its now got a hole in the tank and its cracked.
My question to you all is will the BBOD or ???? change levels to suit the negitive pressure as the volume of the tank has now become smaller. ??? And if I don't get an OEM tank will a tank with lesser volume do the same job?
I'm not running a tank at the moment just a pair of multi grips its seems to be doing the job...
Any help would be great,Thanks Guys
#2 Alex
Posted 30 October 2011 - 05:06 PM
You need to replace the vacuum tank.
kthx.
#3 Scuba-Roo
  • 6960 posts
Posted 31 October 2011 - 05:58 AM
I has one from a gen2 gt
#4 tmh983
tmh983
  • 358 posts
Posted 01 November 2011 - 02:51 PM
It won't have the vacuum capacity to fully open the ecv without the tank, also it uses vacuum to hold the 2ndry turbo IC valve closed, so that valve will open itself when it runs out of vacuum.
What it u do? get a bit too keen with the new engine conversion??
#5 L A R V E N
L A R V E N
  • 20 posts
Posted 02 November 2011 - 05:00 AM
LOL, I wish I could say that but it was in a car park cross section the other car had right of way but I could see around the corner creeper half way and by that time, bang my, fault.? what can you do!
That makes sence about the evac. Car stumbles at 4000 - 4500 rpm boost fails.
#6 tmh983
tmh983
  • 358 posts
Posted 03 November 2011 - 11:51 AM
bugger, unlucky. hopefully u wont have too much trouble finding a new tank, also check that the boost solenoid didn't get damaged
#7 L A R V E N
L A R V E N
  • 20 posts
Posted 03 November 2011 - 12:44 PM
scuba-roo helped me out with a tank from a gen2 mount brackets look
different But ill just weld the other ones on and should be sweet. Fingers crossed the tanks volume is the same. Find out on Friday....
#8 tmh983
tmh983
  • 358 posts
Posted 03 November 2011 - 06:18 PM
i'd reckon as long as the volume is near enough then you should be right
#9 Scuba-Roo
  • 6960 posts
Posted 03 November 2011 - 07:42 PM
Just made it to the post office on time, the post office lady had to delay the driver so I could get this sent off in todays post :)
#10 Murf B4
Murf B4
  • 320 posts
Posted 03 November 2011 - 07:58 PM
i have one out of my b4 , its like brand new
MY02 LIBERTY B4 - LAST DYNO'D @ 375.4KW-ATW    403.5KW-ATW
Next Dyno will be 400+ :)
#11 L A R V E N
L A R V E N
  • 20 posts
Posted 06 November 2011 - 04:16 PM
It works, the mounting brackets needed to be changed. But other then that its all good.... AZZA thanks for letting me use your welder. Scuba too thanks for getting the item to me so quick, LEGEND!
#12 Scuba-Roo
  • 6960 posts
Posted 06 November 2011 - 05:27 PM
Too easy :) glad it works
