Ok so i done my clusterswap on my legacy a while back. All worked fine apart from the check engine light never came on when key was turned to accessory. All the other accessory lights would like oil. battery, steering etc.
So i ripped it out the other day and had a play with the globes. I swaped the Red/White cable with the battery light cable and the check engine globe worked wonders. So going back to the initial swap.
I was left over with 5 cables
I went from non BFM A-C JDM to JDM Type D BFM. Instead of making a harness i just done a straight pin swap while matching up the colours
pinnouts http://sl-i.net/FORU...316fb51b0139077
Brown/White (Height Hi)
Black/Brown (Unlisted)
Black/White (Second alternator light??)
Black (Ground)
Red/Yellow (Unlisted)
B plug
B plug other side
So B10 is Red/White (Check engine light) So i have also tried the Red/White cable in the battery port and still nothing worked.
Sooooo will any of those plugs above that are not used cause this? Im 99% sure the check engine light was working on my old cluster. Oh also my right indicator dash light doesnt work either but im not to bothered as the indicator itself works fine.
