Hybrid motor
Posted 28 January 2015 - 08:18 PM
I would like to make a hybrid say a 207 bottom end and 206 head with all upgraded internals
Has anyone done this kinda thing?
Can someone steer me down the right track
And what options I have
Thank you
Posted 28 January 2015 - 09:12 PM
207 heads flow better than the twin turbo heads due to bigger valves and ports and have a better selection of cams to choose from... use the whole 207!
Posted 29 January 2015 - 08:26 AM
as long as you remove all the rubbish TT system and convert to single at the same time,
why not.
Posted 29 January 2015 - 03:29 PM
Posted 29 January 2015 - 03:35 PM
you won;t get more than 200 ATW
simple, it's been tried and tried and tried before.
the intake is a restrictive mess,
the exhaust is worse with two gas flows merging head on into each other.
and the firing order is all wrong for proper simultaneous operation
If it were good, Subaru would still use it
Posted 29 January 2015 - 03:43 PM
Posted 29 January 2015 - 03:45 PM
Posted 29 January 2015 - 03:50 PM
Billsy was using a 2.2 and possibly a 2.35 in there at some point... i forget.
plus a bank of commodore 64's screwed to the dash running each injector...
Posted 29 January 2015 - 03:53 PM
was excited until I read this. Thought you meant adding a decent sized electric motor
Posted 29 January 2015 - 03:59 PM
Posted 29 January 2015 - 04:32 PM
tell that to the P1 and 918
boom
Posted 29 January 2015 - 06:23 PM
Billsy is just a mad cnut.
As soon as i mentioned 300kw I was in trouble
Posted 29 January 2015 - 07:06 PM
You'd be battling to make much more than that with a vf34 on E85.
I'd say with a larger intercooler and some hybrid TD04's you'd see plenty more power. Pretty good around town too.
Posted 30 January 2015 - 03:06 PM
Posted 30 January 2015 - 06:47 PM
Posted 30 January 2015 - 06:48 PM
Changing head gasket thickness, someone may know how to do the calculation.
Posted 30 January 2015 - 06:57 PM
Posted 30 January 2015 - 07:07 PM
Why chase a 207 specifically if you are going to change the pistons?
Posted 30 January 2015 - 07:33 PM
Posted 31 January 2015 - 01:12 PM
pistons are virtually all the same, the variants are comp ratio, forged or not and oversize!
ej20s are ej20s thats the beauty of them
the 207 block is a semi closed deck thats what is the desired part
