oil leak from turbo
Posted 30 January 2015 - 01:25 PM
I have a major oil leak coming from turbo on drivers side any ideas to rectifying issue.
Start car up and literally drips oil down profusely.my02 b4.std engine and turbos.
Posted 30 January 2015 - 02:49 PM
Hmmm Turbo seal??
Replace turbo?
Posted 30 January 2015 - 03:05 PM
The seal is usually internal - drips into exhaust / intake tracts and you blow a whole heap of oil smoke.
You might (hopefully) find its something as simple as one of the oil lines to/from the block. Each turbo has a hard pressurized feed line and a rubber low-pressure return line.
With any luck, you've sprung a leak in one of the pressurized lines or banjo bolts.
Posted 30 January 2015 - 03:57 PM
Doesnt blow any smoke but drips constant amount of oil..
I had the vacuum line aroubd wrong way it was fine.as soon as put back to normal way oil drips..
Posted 30 January 2015 - 06:10 PM
As Dunc said, likely to be the feed or return. The feed will be easier to get to than the return. Take off (or get someone) to remove the heat shielding to get a better look. Trace the hardline till you find the source of the leak, be sure to check the bolts at either end for play. If it's not the hardline, it'll be the return line which is a rubber one with a crappy pinch type clamp. If it's that, check the hose for splits or misalignment and pop on some proper hose clamps.
I don't understand what you're saying about the vacuum line.
Posted 03 February 2015 - 09:16 AM
I had quick look yesterday and the centre clamp holding turbo together in middle did up a fair bit.im gonna put intercooler bak on and degrease and run this arvi c if any better if not ill check out oil return and feed lines for leaking.
Posted 03 February 2015 - 07:12 PM
I dont know if was just to clamp being loose or he had vacuum lines around wrong way.maybe pressurised turbo and forcing oil out of clamp.
Posted 03 February 2015 - 08:04 PM
well done.
I've no idea how the sealing on these turbos works -- but I'm guessing the swapped vac lines prevented the secondary exhaust valve ever opening up - so the secondary didn't see exhaust or intake pressure, and so no leaks.
As soon as you fixed the lines, secondary was spooled up and exit oil stage left.
Posted 12 February 2015 - 05:52 AM
I dont think it is coming from the turbo i think its ccoming from the t piece breather just under the secondary turbo off the pcv..
Is this common?i checked pcv and it was gummed up a Bit so cleaned it out but yet to start motor and see if leak still pesent and as dramatic.
Posted 12 February 2015 - 06:51 PM
Oil shouldn't leak as such from there. If anything, just vapor will escape through the breathers, unless your crank case is heavily pressurised which means something is terribly wrong.
I'm still convinced it's the oil return line under the secondary, or the metal feed hard-pipe to the secondary head side.
Posted 12 February 2015 - 10:52 PM
If it is a heavy leak then I also would be pointing fingers at the return line. The rubber hose goes hard and brittle and will consequently lose it's seal.
Posted 13 February 2015 - 09:03 AM
Posted 13 February 2015 - 07:06 PM
Absolutely p##sing out..
Must just have beem old stuff up top but after a good degrease i started engine and within 10sec oil literally pouring from between sump and gearbox down onto rack..
Like there isnt a seal in there. .
Posted 13 February 2015 - 07:20 PM
Is your timing belt or clutch due yet?
Posted 13 February 2015 - 08:22 PM
Its done 180000kms so timing belt almost due.what is it i read on a plate that sshould be changed when doing rear main? Genuine seal only yes?
Posted 13 February 2015 - 08:47 PM
I wouldn't use anything else other than genuine. Was going to suggest, do your timing belt at the same time and anything else that needs attention. Good chance to make sure ALL oil lines and water hoses are in good condition, do as much as you can while the opportunity presents itself.
Posted 13 February 2015 - 08:55 PM
cheers for the help.
Posted 13 February 2015 - 09:17 PM
Well guy i bought it off reckons leak was from turbo and leaked down into box ruining clutch plate so he told me he changed rear main seal
what's the bet he stuck it in too far? Its easy to do. Rear main seal should only be pushed flush with the block.
If the engine's being pulled to do the seal, best to get everything else done at the same time - much easier.
Clutch + throwout bearing, timing belt, water pump, etc
Posted 13 February 2015 - 09:21 PM
Still b good buy and ill know everything be spot on.
Posted 14 February 2015 - 09:44 AM
While you've got the engine out I'd also be doing the crank and cam seals, cam cover plate seals and if the little cover plate in the bell housing is plastic replace it with the pressed metal unit (available from subaru). I don't know when they crossed back to the metal plate after going with plastic for a while.
As previously mentioned, I too reckon the rear main seal has been pushed in too far - very easy to do for a noob on this. My mate did it but I found it before we put the engine back in the car, cost us a seal but saved us a pot load of time!
Also a good time to replace any radiator and vacuum hoses too.
