Gentlemen,
Seem to be having a problem with my climate control heating. I cant get the thing to put out any warm air until I wind it up to 32 degrees. It's cold/ambient until it's cranked right until literally 32 degrees, where it will pump out 32 degree air. All other temp settings below 32 are the same.
I have no gurgling or water problems behind the dash which makes me think something might be wrong with the unit itself? If not that, is it likely to be a blocked heater core?
Jimbo, out.
Climate Control Issues
Posted 04 April 2015 - 09:46 PM
Posted 04 April 2015 - 10:14 PM
From what I was told by Ben at ichiban when my climate control unit failed on the Heritage, your import(?) has a sensor within your dash as opposed to AUDM models coming with the sensor built into the front of the control unit. Best to ask Ben on this issue perhaps?
Posted 05 April 2015 - 08:21 AM
Do these units have the ability to run a self check? Nugget Commodores from the late 90's could, and Im wondering if these have a similar feature.
If can pump out nice hot air then I doubt it will be a blocked heater core. You can check by feeling the heater hoses with heater on flat out.
Posted 05 April 2015 - 09:19 AM
It does everything fine, A/C is good, reads the temp correctly. It just wont push out any warm or hot air until set to 32 degrees. Normally on a cold day, sitting on about 22-25 is ample. Was just blowing ambient air.
Posted 05 April 2015 - 09:28 AM
Posted 05 April 2015 - 04:14 PM
Posted 05 April 2015 - 06:00 PM
Posted 05 April 2015 - 07:52 PM
I would assume that's the sensor in the bottom right hand corner behind the small round bezel? It has a corrugated tube running from the back of it, behind the unit.
Posted 05 April 2015 - 08:07 PM
Okay, just found the procedure to check the unit and got the following results.
DTC Error Codes -21 and 25. Note at the bottom of the Workshop Manual :
Looks like I need a new one. Any difference between JDM and AUDM?
Posted 05 April 2015 - 08:56 PM
Posted 05 April 2015 - 10:04 PM
If it's the sensor I think it is, should be able to. Probably easier to replace the whole unit.
Posted 05 April 2015 - 10:11 PM
Most likely they would be the same Id imagine.
