Hi All again,
Ok, so ive tried a fair bit and now i need some experienced people to help.
I am trying to read the fault codes on my 04' RX impreza, however after buying the bluetooth, USB and Wifi OBD2 dongles i still cannot connect.
Ived looked for similar posts about OBD2 issues bofore and cannot find much (probably looking in the wrong spot)
The furthest i get is i found a few youtube videos about how to fault find a bad OBD2 plug.
this was the most helpful video i found and used
So i followed the steps and established it wasnt a power issue.
All grounds were Grounded
Power to OBD (pin16) was correct.
Power to K-Line was 0.0V, which in the video says its bad, as it should have approx 3.5V
so i disconnected the batter and tested the resistance of the lines (pin 4 and 5) ground and signal ground.
both came up with a value of 0.1 oms
and K-line (pin 7 ) = 111.7K oms (0.1117 oms)
in my opinion this isnt enough to justify there is an internal fault / a controller grounding out.
my only option is to follow the K-line back thought each plug and find the fault.
HOWEVER!!! if anyone has ever tried to follow a line back though looms... there is a lot of taped up wires and Y junctions ETC....
I pulled the dash off again and re tested the lines, after testing the voltage I thought i would try the voltages again with the ACC on,
this time i got a reading from the K-Line
= 7.3V..... WTF? (0V with key off)
so i plugged the obd2 reader in and it still didnt work.
I have tested the OBD2 reader on my other car and it works fine. so its not the reader.
I have Used a friends OBD2 reader before about a year ago and it worked fine.
CAN ANYONE HELP WITH SOLVING THIS PROBLEM?
OTHER THAN FOLLOWING THE LINES BACK THOUGH EACH PLUG WHICH IS A PAIN IN THE ARSE.
HAS ANYONE EVER HAD THIS ISSUE BEFORE ?
DOES ANYONE HAVE A THREAD WHICH ADDRESSES THIS ISSUE?
Im sure ill get trolled for this but short of getting an auto electrician to charge through the nose to fix it im fresh out of ideas.
thanks.
