Not sure if this is in the right spot, sorry if it is but I got a check engine light come on then went out. It was only on for maybe 20 seconds then went out. I parked it later on I went out to give her a start and she started ran like normal. Should I be worried do need to check for codes ? Thanks
Intermittent check engine light
Posted 19 August 2015 - 10:24 AM
Posted 19 August 2015 - 11:59 AM
Posted 19 August 2015 - 01:02 PM
Check engine light will flash a sequence. Long flash for first digit and short flash second digit of trouble code.
Eg: Flaaaash Flaaash Flaaaash Flash Flash would be code 32. There is a pause between seperate error codes. Reference the codes on Google and you will get the answer.
Keep the plugs connect and drive moderately to clear the ecu. Once the ECU is clear, CEL will flash rhythmically.
Posted 19 August 2015 - 02:18 PM
Hopefully it's logged one and it will spit out the number.
Ben
Posted 20 August 2015 - 03:05 AM
Thanks guys , ya it's the first time I have seen that happen so what I will do is see if it pops up again if does not I will pull the codes saturday.
Posted 20 August 2015 - 07:46 AM
I have one for my 3GEN and I even sometimes check the codes while driving the moment I see that blasted orange light.
Posted 20 August 2015 - 07:59 AM
Posted 20 August 2015 - 09:45 AM
Posted 20 August 2015 - 01:39 PM
Rev a ?
Posted 20 August 2015 - 01:55 PM
Posted 20 August 2015 - 02:52 PM
A very wild guess..... knock sensor.
Posted 21 August 2015 - 12:53 AM
Does it state the Revision type on vin tag ?
Posted 21 August 2015 - 10:13 AM
Can the can be in limp mode and the cel not be on ?
Posted 21 August 2015 - 12:15 PM
Posted 22 August 2015 - 03:10 AM
Its a B
