the workshop manual said the fuel pump relay is connecting to a green plug that located underneath of the passenger side foot well.
Can anybody tell me where the fuel pump relay is (pic would be better)
Posted 09 October 2015 - 12:13 PM
Posted 09 October 2015 - 12:52 PM
Drivers side footwell under the steering column next to the fuse box, its a round silver thing.
Posted 09 October 2015 - 01:07 PM
Posted 09 October 2015 - 01:08 PM
so what is this thing, it also called the fuel pump relay. I bought it off ebay.
http://www.ebay.com....-/281513034021?
Posted 09 October 2015 - 02:15 PM
Posted 09 October 2015 - 02:16 PM
That's the fuel pump control module -- the turbo models have a variable-voltage supply to the pump (I think its 1/3, 2/3 and full on), whilst the NA's just have on/off via the relay.
It lives in the boot - left-side panel. Behind the panel forward of the jack in a wagon, somewhere similar for a sedan according to the wiring diagram.
Posted 09 October 2015 - 02:22 PM
Yup. I think there is also a slow blow fuse in the engine bay for the fuel system too.
Posted 09 October 2015 - 02:44 PM
thank you for the input guys.
I am having problem starting the car only when its hot. I did a bit of research on the forum and youtube and a few of them fixed this problem with a fuel pump relay replacement. is that means I have to replace the round metal one?
Posted 09 October 2015 - 02:52 PM
mmmmm... I'd check the pump was not working before I replaced the relay.
You should be able to hear the pump come on 'high' for a few seconds (noisy), then throttle back to the 1/3 quiet mode when you turn on the ignition (without starting). Dig in under the RHS rear seat cushion where the pump lives if you can't hear it.
Check that it isn't turning on when you have your hot start problems... then check the voltage at the pump contacts.
Could be dodgy relay, dodgy pump, dodgy pump controller (they are known to die sometimes, I think). If you bought a new one, then plonk it in and see if your problem has gone.
Posted 09 October 2015 - 03:26 PM
I will try this thx!!
do you have a Brant alarm?
I still have the Brant alarm in my car. Does it matter?
Posted 09 October 2015 - 03:33 PM
My car was playing up and not starting when it was warm but couldn't figure out what the issue was. After a while the fuel pump was started cutting out intermittently while driving which is obviously very dangerous so got proper stuck in to find the issue. It turned out to be some dodgy wiring with the installation of the Brant alarm to the fuel pump relay was causing both issues. We removed that point of imobililisation from the alarm and its been fine ever since.
Posted 09 October 2015 - 03:51 PM
Even if the Brant is wired well enough, there are small relays in the Brant. Hot and cold weather can crack solder connections. When the pump is dying it can draw more power. My mechanic explained that the pump had been dying for a while, took the Brant and fuel pump controller with it. You can try bypassing the Brant for the fuel pump, just make sure you solder it really well and tape it up well. Those round fuel pump relays are quite solid and he had not heard of one failing before.
Posted 11 October 2015 - 01:25 PM
any workshops in brisbane that you guys recommend to do the Brant alarm removal? and usallly how much do they charge for this?
Posted 14 October 2015 - 10:59 PM
Today I have replaced the fuel pump controller in my B4 and it seems like the car start every time in several hot start. Problem fixed
