Subaru B4: Cam Shaft Sensor and/or Alternator Issue
#21
Posted 08 January 2017 - 12:50 PM
I now occasionally get a very slight misfire on idle if my lights or air con are on. Usually around town on short trips where the battery doesn't get a good charge.
It's barely noticeable and not enough of a problem for me to devote any time or money to. I don't get any error codes for the CPS either, but I know it is voltage related.
It might be bad wiring, I know better earths helped me, but if you are looking for another alternator and not afraid to spend a little more, try OEM.
#22
Posted 21 July 2017 - 09:40 AM
im having the exact same problem with my b4, changed the alternator ot with a second hand one and didnt help at all
#23
Posted 21 July 2017 - 10:17 AM
I still occasionally get a misfire with the headlights on now, but hardly noticeable now.
Have you rewired your cam shaft sensor? I did and it helped. You will want to use shielded wire and run it all the way from the sensor to the ECU.
#24
Posted 08 June 2018 - 10:45 AM
Reviving this thread.
So the generic alternator I bought has started to have issues running my HIDs at idle. They will flicker.
I tried swapping back to my old alternator out of interest and it was certainly the key cause of my Cam Position Sensor problems.
Looks like I need to get a new alternator. I'm looking at a GEN4 model 23700AA520 second hand unit. Can anyone confirm it has the right plug?
