Troubleshoot: Oil Leak
Posted 30 January 2016 - 11:15 AM
Whilst under my car today I noticed a worrying amount oil loss from the rear main seal area. Now I have recently had both this and the oil cover plate replaced for the 2nd time in 8 months. It is becoming very apparent that this issue isn't result of dodgy servicing and may be something else. As such I was wondering what thoughts their are on why this may be occurring. I am led to believe it may be in relation to crankcase ventilation however I am unsure what parts control or assist in this process. Guidance would be loved.
Cheers sluts
Posted 31 January 2016 - 09:46 PM
Keep it simple. Get the engine fully degreased. Get it thoroughly checked after 200k's and then get a second opinion. Subarus leak down from crankcase breathers, turbo oil returns, head gaskets, valve cover gaskets, sumps and just about everywhere else as it all gets blown backwards as you drive. Very hard to diagnose over the internet.
Posted 01 February 2016 - 08:52 AM
Posted 01 February 2016 - 10:40 AM
How many KM's on this engine?
Posted 01 February 2016 - 07:14 PM
Posted 01 February 2016 - 07:16 PM
Have you checked the oil feed/drain lines underneath the turbos?
Posted 01 February 2016 - 07:59 PM
Posted 01 February 2016 - 09:02 PM
Posted 01 February 2016 - 09:33 PM
Checked both turbos. No signs of leaking. It's appears to be very visually coming from the seal between engine/transmission
Sounds like either the rear main seal of the rear separator plate. Engine or box out to fix unfortunately
Posted 02 February 2016 - 06:26 PM
Posted 02 February 2016 - 06:45 PM
maybe they fooked up the install - easy to push the rear main seal too far in, or scratch the housing.
Posted 03 February 2016 - 10:08 AM
Or lip/groove in the crankshaft surface caused by the original seal.
