just wanted to get the brain trust's opinion on my daihatsu cuore
So I got my brakes repaired for constant glazing turns out it was some stuff in the guide pins that was not letting the caliper release all the way creating burn marks on the rotor and glazing causing a creaking noise as I drive.
Now after fixing that, the creaking noise has come back but only when I brake, not as I'm driving so we know that the caliper is released fully when not pressed. The sound is kind of different now, sounds like the pad is loose so I'm assuming it has to do something with the brake clips.
Any ideas?
This is basically the noise
