lol, I spent about 6 months diagnosing clunk sounds in the front end of my B4. If it only happens under braking when you turn right, it might be brake pads moving in the calipers. Bendix pads are known to shrink as they wear. Probably the weirdest diagnosis we found out for mine. Prior to that I had changed swaybar bushes, steering rack bushes.. the noise remained. The noise started after the front passenger wheel bearing failed, and they had to replace the hub and the CV. The best fix was a genuine brake pad kit with new shims and clips.
If you can move the pad with a screwdriver, its a possible issue. You either put up with the noise until the pads are worn and need replacing, or change them because its driving you nuts. But it could be something completely unrelated, moral of the story, clunks that occur under certain conditions are a cvnt to diagnose.
