Sensor question for GC8 wrx
Posted 07 April 2016 - 04:17 PM
Posted 07 April 2016 - 04:33 PM
Posted 07 April 2016 - 04:54 PM
Bosch are also a good option.
come complete with the OEM length wiring and plug too
http://au.bosch-auto...-shop.com/en/43
About $130
Posted 07 April 2016 - 06:06 PM
Posted 08 April 2016 - 11:11 AM
Posted 10 April 2016 - 11:50 PM
Posted 11 April 2016 - 03:25 PM
with the car at warm idle
put your multimeter between earth and the signal wire,
you should see the voltage swing from 0.1v to 0.9v and bsck again over a couple of seconds
if it's slow or doesn't swing, sensor is toast or you have an air-leak upstream of the o2 sensor
Posted 11 April 2016 - 06:58 PM
Thankyou for your help
Posted 11 April 2016 - 08:54 PM
Posted 12 April 2016 - 09:43 AM
As above
when you probe them relative to ground you'll see 12v, 0v and the signal.
there's no doubt a complete service manual round here with wiring diagram to show colours and connectors.
Posted 12 April 2016 - 07:21 PM
Subaru want $485 for the part! Holy smokes! I can get it from UAE for about $218 delivered. Part number from Subaru was 22690AA321
Posted 13 April 2016 - 12:16 PM
Putting a scanner on it is also a great way for your auto-sparky to make money.
the 100% foolproof way of testing it is with a multimeter as I posted.
you can do it at the ECU pins also, that tests the wiring is good aswell.
As previously mentioned, get a Bosch one
from www.efi.com.au, about $130
Bosch Part# 2269013255
Done
Posted 14 April 2016 - 08:22 AM
