Hi folks, have removed square type electric fuel pump. Hooked it up to a battery, it sputters for a moment then stops. Should this pump run constantly when powered? Or are they just a type of priming pump?? Or is it screwed? The carbied engine cranks fires and dies. Any help would be great, many thanks.
l series fuel pump problem
Started by thumpa1, Apr 17 2016 09:39 PM
1 reply to this topic
Posted 17 April 2016 - 09:39 PM
Posted 19 April 2016 - 11:31 PM
G'day thumpa,
Sounds like its rooted. Get a new one. When constant power is applied it should keep jiggling away.
In the L series it needs to register that there's spark to excite the fuel cut relay system so that fuel supply keeps up once the engine starts to crank
