I had a problem recently with my RS hesitating whenever it got to around 4500rpm in any gear. I read this could've been caused by the fuel filter/pump so I replaced them both. Installed a Walbro 255 and found that the car previously had a DW200 in it. The car started again fine after the new filter and pump but I didn't drive it. Got in it last night and the problem has gotten much worse, the car will bog down just as boost is about to come on and it feels like a fuel/boost cut. The engine wont stall but will struggle for 3 seconds then will continue running. Keeping the car under 2000rpm it seems to bog down randomly without anything happening.
I'm getting a list of stuff to look at tonight and was wondering if anyone can add to it.
- Swapping out the maf for another
- ECU reset
- Check plugs
- Different cam shaft sensor
