I came across this today while having a look under my steering wheel/dash
Looks like someone has put two pins into the end of one of the cables,
Could someone let me know what this does?
and can i remove them? as im pretty sure there not stock
Picture below:
Weird pin in cable under dash
Started by Delete This Account, Jun 20 2009 03:42 PM
2 replies to this topic
Posted 20 June 2009 - 03:42 PM
Posted 20 June 2009 - 04:21 PM
LMAO... thats looks like a kosti method of "closing" the loop.
To reflash your ECU you have to plug the 2 green connectors together and then usually plug in a closed loop plug into that same connector which will close the loop. Looks like kosti just done it on the cheap with some paper clips.
Edit:
You can remove them, and they are not stock. I've got an actual plug that connects to it....... from what it looks like you just have to stick a paperclip over the 2 pins to create the loop.
Just Married
Posted 20 June 2009 - 04:42 PM
lol but my Ecutek tune was done at S&J, so they must of done it haha cheers for the info Jeff
