Car won't start after Fuel pump was put back on
Posted 18 September 2016 - 12:06 AM
Posted 18 September 2016 - 08:16 AM
ECU controls fuel pump and will run the pump for a few seconds when key is first turned on. If the ECU doesn't see an 'engine start' condition within that time, it kills the pump. Normal.
Double check your hose connections.
BTW. If you were removing the filter, why not just replace it?
Posted 18 September 2016 - 12:21 PM
Because I can't find it locally and this is my Daily so I ordered one off ebay when it comes I'll replace it Thanks for your reply but it didn't help my problem.
Posted 18 September 2016 - 05:40 PM
Diagnostic steps one must always use when things you touched don't work any more.
1. what could I have possibly forked up?
2. check items identified in 1.
3. reduce your assumed level of intelligence you used when putting it back together
4. return to step 1.
Posted 18 September 2016 - 10:57 PM
cause what Jase discribed is exactly what everycar does
When the car doesn't start it will cut the fuel pump
It only primes for 3 or so seconds
It should have fuel flow during cranking
Posted 19 September 2016 - 12:10 AM
Posted 19 September 2016 - 12:21 AM
That said I'd think with the amount of cranking you described the pump would've built enough pressure for the engine to fire.
You haven't touched any fuses or relays for sure? Haven't been playing with wires above driver's kick panel (such as diagnostics plugs)?
Is the correct line being pressurised? I don't know if it's possible to cross the return line with the IN line but it's a thought. I doubt the fuel regulator would let fuel in from the wrong direction.
Posted 19 September 2016 - 12:58 AM
Ok it was because the Cam sensor wire had some how come loose! Reconnected it and all fired up Thanks everyone for the help
#9 Guest_KONG_*
Posted 19 September 2016 - 08:08 AM
Posted 21 September 2016 - 06:36 PM
I bet it's the Cam sensor wire
Like Kong says,sometimes when doing fuel pump checks the camshaft position sensor wires can become loose.
Edit: I nearly choked on my garlic bread when I read that, you swine.
