Head Gasket replacement
Posted 01 July 2009 - 02:34 PM
I've got a buddy who recently bought a Gen2 RX and has suffered at the hands of the evil DOHC EJ25 that these vehicles are equipped with.
I am looking in to putting in the new head gaskets myself, and have been doing quite a lot of research on the topic (not having done it before, there is a lot to read!). I've got a Haynes workshop manual which details the entire procedure from start to finish, but I have also tracked down some additional websites. In my experience it always is a lot easier to cite the information from various sources, as each source explains it and displays diagrams in different ways. This all helps and gives me a better understanding of the task at hand.
I've purchased head gaskets from Subaru (2 required to do both heads) and the part number for this particular vehicle is in my parts number thread.
I will have to look in to head studs, cost and requirements for those as well as any other parts that are absolutely necessary. At this stage we are looking to do just the gaskets themselves as my friend is out of a job and does not have much money left for repairs after the initial purchase.
As I progress I will update this thread, I will also look to get scanned copies of the relevant section / pages from the Haynes manual - these things are worth their weight in gold!
Dylan
The page links are below:
- http://home.comcast....eplacement.html
- http://wac.addr.com/...headgasket.html
Posted 01 July 2009 - 02:44 PM
Posted 01 July 2009 - 02:49 PM
hey mate sorry to go abit off track but where would be the best place to get one of these workshop manuals
you speak of so highly????
cheers mate
Ben
No worries mate.
I bought mine online, direct from Haynes. Cheap, fast and VERY worthwhile purchase. I'll most likely buy another one soon, as mine is covered in grease and looking a bit worse for wear since I did my conversion
This thing could potentially save you thousands upon thousands of dollars if you're willing enough to give it a go.
Posted 01 July 2009 - 03:05 PM
No worries mate.
sounds like a good investment...well to cut a long story short bought a 97 rx. got f**ked over. needed new moter.bought one from aek.got car fixed.. now have a spare ej25 that i was thinking of having a crack at fixing myself just for somthing to do!!!!so thought a workshop manual would be a good place to start...
Posted 01 July 2009 - 03:15 PM
Absolutely. It gives detail on an entire engine tear down, clean and rebuild. No diagram or information spared in these Haynes manuals.
Posted 01 July 2009 - 04:19 PM
Posted 01 July 2009 - 04:23 PM
Posted 01 July 2009 - 07:19 PM
Posted 01 July 2009 - 07:48 PM
Jap Spec EJ25 - 6000k hid kit headlights and fog lights - Leather interior - 18" incubus rims - Super low suspension - Turbo Bonnet - 2.5 inch catback with cannon - front mounted 6x9"s connected to amp - 2 x 12" fusion subs - Pioneer head deck. + turbo timer just because i had one lol
Posted 01 July 2009 - 10:34 PM
GLADBAGS!!!,GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!
do i need to say it again.. YES!!!
GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!GLADBAGS!!!
I did this just before xmas and putting EVERYTHING possible in GLADBAGS!!! and then labeling it makes things so much easier!
also i have got the 97 and 98 service manuals from subaru uploaded
I did this whole job start to finish in 3-4 complete days, it was just me and i have never worked on an engine before so im sure you will be fine!
just use GLADBAGS!!! lol
and skips site is GOLD! as is rs25.com and nasioc.com, RS25.com is gold for the gen2 DOHC cause its the same motor all their non turb impreza's use and as such there are literally thousands of threads about doing head gaskets and the whole engine removal process.
one thing i cant stress enough is you will need to use some initiate and be ultra carefull when removing the timing belt and the cam sprockets as they are under tension and on one side if it slips the wrong way you will likely cut your finger off or if it goes the other way you will bend valves.. both not good, but the later is worse cause you mate will then probably still cut your fingers off lol
dont hesitate to give send me a PM or leave a msg on my msn (its on 24/7) jazzao_o@h0tmaildotcom(replace o's either side of "_" with ZERO's)
good luck
oh.. and >>>> http://members.iinet.....erty Manuals/
Posted 01 July 2009 - 10:46 PM
