'01 & '98 Forester gearbox compatible?
Gearbox compatibility
1 reply to this topic
#1 RexMcG
RexMcG
  • 1 posts
Posted 03 March 2018 - 11:16 AM
Hi,
I need to find out if I can have a manual gearbox pulled out of an '01 Forester & put straight into a '98 Forester?
Thanks, Rex.
#2 El_Freddo
El_Freddo
    Rock'n the old Skool
  • 2,315 posts
Posted 04 March 2018 - 11:12 AM
It'll fit but may need a matching rear diff ratio to make it work properly.
There may be speedo accuracy issues but you'll be able to drive it without an issue otherwise.
Don't stress about the 4 bolt/8 bolt difference at the bell housing, just use the available bolts on the engine and it'll be fine.
