EJ25 GEN 3 LIBERTY RUNNING ISSUES
3 replies to this topic
#1 iSplatty
iSplatty
  • 2 posts
Posted 25 September 2018 - 12:34 PM
Recently I've been having some with issues with how my liberty has been running, it was hesitating, jerking an not giving a smooth delivery of power, i theorised it had to be fuel related, as i had cleaned out every single electronic connector when i had the pleasure of blowing my head gaskets an fixing things myself.
My mechanic diagnosed the problem as i had theorised, an replaced the injectors, plugs, as well as leads as mine were on their way out.
We went for a test drive, an even after all of the diagnosing, we still had the slightest hiccup when: changing gears, initial start up, as well as letting off the accelerator. My mechanic couldn't figure out the problem
Since then i have changed the fuel filter (black), thinking this would be my smoking gun, but still no result.
Can anyone shed some light onto this issue?
Could it be the fuel dampers? I haven't changed these yet.
#2 crjohnson
crjohnson
  • 201 posts
Posted 26 September 2018 - 10:19 AM
any fault codes showing up? I'm not sure how to do it without an OBD cable but would be a good starting point!
#3 iSplatty
iSplatty
  • 2 posts
Posted 28 September 2018 - 11:40 AM
no codes at all,
mechanic went over everything with a fine tooth comb.
There is only two things i haven't done myself an that's:
1. replace the catalytic converter (hearing rattling from a loose piece) as well as
2. those fuel damper valves.
#4 El_Freddo
El_Freddo
    Rock'n the old Skool
  • 2,245 posts
Posted 05 October 2018 - 11:38 PM
Check/clean the idle air control valve (IACV). It will be dirty and not doing its job quick enough, hence stalling and stuttering.
