Low and surging idle
7 replies to this topic
#1 Chaapppppp
Chaapppppp
  • 38 posts
Posted 14 November 2018 - 08:07 PM
Hi,i have a '97 rs legacy twin turbo.
Idle is very low and surges, sometimes car stalls when stopped.
I have:
Cleaned iacv
Cleaned throttle plate/intake
Reset ecu by disconnecting battery
Anyone have any suggestions?
#2 El_Freddo
El_Freddo
    Rock'n the old Skool
  • 2,314 posts
Posted 14 November 2018 - 10:11 PM
Got any codes?
Also cleaning the contact points on the throttle position sensor could be worth the effort. Then re-adjust the tps’s setting following the workshop manual.
Thermo fans on all the time? If so, temp sensor is dead ;)
#3 Chaapppppp
Chaapppppp
  • 38 posts
Posted 15 November 2018 - 03:04 PM
No codes, however i disconnected maf sensor while car was running and it didn't die🤔
Does this mean maf is bad?
Thermo fans are all good.
Thanks
#4 podmak
podmak
  • 104 posts
Posted 22 November 2018 - 08:53 PM
You guys have a workshop manual for gen2 twin turbo? Would you share please?
#5 Chaapppppp
Chaapppppp
  • 38 posts
Posted 24 November 2018 - 06:54 AM
Not the maf, only have a haynes hard copy i bought from super cheap auto bro.
#6 Ads
Ads
  • 98 posts
Posted 24 November 2018 - 07:39 AM
Checked plugs? I had the same symptoms intermittently up to the point where it wouldn't even start. Turned out to be fuel fouled plugs from running rich, possibly due to an injector issue (stuck or clogged). Surprised you are not getting any codes though..
#7 Chaapppppp
Chaapppppp
  • 38 posts
Posted 26 November 2018 - 12:48 PM
Starts fine, haven't checked plugs but they were replaced 6 months ago though
#8 Chaapppppp
Chaapppppp
  • 38 posts
Posted 27 December 2018 - 06:22 PM
All sorted, did timing belt etc and now idles mint as👍
