PLEASE HELP!! Swapped turbo from vf34 to td04 and idles rough
Posted 20 May 2019 - 02:28 PM
Posted 20 May 2019 - 02:42 PM
Idle has nothing to do with the turbo, unless it blocked or something really silly.
You've probably introduced a post-MAF intake leak..
(though I guess its possible that if the idle was tuned for the VF34, the extra restriction is causing idle problems on the TD04.)
Posted 20 May 2019 - 02:44 PM
Yeah moneys on vac leak. Make sure the turbo inlet is seated properly all around the turbo. Its possible through changing the turbo a few times the inlet has torn and needs to be replaced
Posted 20 May 2019 - 03:57 PM
Posted 20 May 2019 - 04:35 PM
so - let's clarify.
Smoking from turbo -- lots, or just grease and oil you had on your hands which is burning off as it heats up? If its persistent, then you've got an oil leak, no?
Knocking - big and clunky, small, fast, slow, with engine speed, at turbine speed, loud, quiet? Need details.
To find the source of mechanical noises, a length of wood held to the ear and then hard against the suspected object always helps.
Posted 20 May 2019 - 08:08 PM
I’d say that you were pulled over for another reason, then the car got a going over as a result of pervious actions or some lip given to the officers that pulled you over. So what’s the real story?
(I’m curious)
