2004 subaru liberty cooling system issues
Posted 06 September 2022 - 09:41 PM
Posted 07 September 2022 - 08:43 AM
Pull off the radiator hoses and run a garden hose through the inlets/outlets. Anything else is going to require disassembly off the water pump/engine.
Replace the cap and fingers crossed that was the problem. Sounds like a blown headgasket
Posted 07 September 2022 - 09:50 AM
Posted 07 September 2022 - 05:19 PM
Posted 20 September 2022 - 06:11 PM
Posted 21 September 2022 - 08:28 AM
OEM only
Posted 21 September 2022 - 07:05 PM
Ben
Head gasket jobs aren't cheap, and secondhand engines are usually cheaper, which is why the mechanic has recommended what he said.
Posted 21 September 2022 - 09:14 PM
Add all that up and it’s cheaper to buy a JDM import second hand H6 and drop that in.
But if you want to run what you know works/what you’ve got, go for it. Your wallet will have a serious weight loss work out in a very short amount of time!
Posted 21 September 2022 - 10:49 PM
Posted 22 September 2022 - 11:22 PM
There are many timing case bolts 50-60iirc as there are 2 timing case covers. The rear cover has a handful of O rings that seal the cover to the heads and block.
I also replaced all the timing chains, guides and tensioner while I had it apart. All parts were genuine supplied by Partsouq
