Head gasket?
Posted 30 August 2009 - 10:30 PM
Posted 31 August 2009 - 12:03 AM
Posted 31 August 2009 - 12:40 AM
Posted 31 August 2009 - 01:46 PM
Johnno gimme a call or msg me this week, let me know when you're around and we'll meet up.
You also have the option of taking it to Toy's but give me a call / sms first and we'll sort something out.
Dylan
start the car and let it warm without the header tank cap on.
this will get rid of the air in the cooling system, is its air that is causing your problems.
otherwise yes i will take it to toys hahaha
how is the gear box going all good?
For all Your Performance Work and Needs.
Address : 8/88 Seville Street
Fairfield East NSW 2161
PH : (02) 9755 9882
Posted 31 August 2009 - 05:19 PM
Posted 31 August 2009 - 05:22 PM
Posted 31 August 2009 - 05:40 PM
Posted 31 August 2009 - 06:08 PM
Posted 31 August 2009 - 11:48 PM
Posted 01 September 2009 - 10:14 AM
Posted 01 September 2009 - 05:10 PM
On Friday night, the temp needle did get close to the H, smoke came out of the bonnet. Turned into some back roads to get more airflow, temp needle went back down around the middle. Car then conked out (different electrical issue), and when I got her towed I noticed a pool of liquid on the road where the passenger front side of the bay was, guessing coolant now.
Driving it yesterday, before I noticed the overflow bubbling, the high setting didn't get to 16psi as it normally does. Did feel a bit sluggish, not rough, thermos are mostly on.
Just did what you fellas suggested, topped up header tank to while waiting for the car to warm up then went for another 5 min drive. Temp is 13 deg on the climate, taking it pretty easy, needle gets to halfway pretty quick (normally stays about a quarter). Bottom radiator hose is still cold, top is fairly warm, overflow has filled up almost to the top - it was under halfway before the drive.
Let it cool down, then topped up the header tank again and took it for a more spirited drive. Overflow now spilling over and onto the front bar. Bottom radiator hose still cold - is this normal? Will book it in for a TK test and test out the radiator.
sounds like your thermostat is stuck closed!!!
take off the bottom radiator hose and remove the housing and pull it out and replace it. genuine subaru ones are around $20.
Posted 03 September 2009 - 01:21 PM
Posted 03 September 2009 - 03:23 PM
Posted 03 September 2009 - 08:23 PM
Posted 03 September 2009 - 10:45 PM
GEN1 Red Mica RS Liberty - Stock factory original
Love is a Legacy, Liberty, etc......
Posted 04 September 2009 - 12:51 PM
Posted 23 September 2009 - 01:18 AM
