Engine annoyances
Posted 01 September 2009 - 05:56 PM
Posted 01 September 2009 - 06:33 PM
Posted 01 September 2009 - 06:34 PM
Posted 01 September 2009 - 08:02 PM
do you mean the idle is hunting a bit? how low does it drop on the tacho?
are you letting the car warm up before you drive it???
ps. if your doing high k's dont forget to change the oil and filter every 5000k's. if you want to use the same stuff i was using its fuchs 10w40 SuperGTO full synth.
Alex, It doesn't do it when cold, only after driving a bit. but the revs drop nearly down to 0 then it picks back up again. it doesnt stutter or anything like its going to stall but enough to make me think it might.
I let the car warm up for a couple of minutes, as long as it takes to reverse out of my shed, close the door, drive to my gate, open gate, drive through, close gate, then i drive off. but after that i just go through the gears at low revs so its given enough time to warm up before i drive it hard.
the revs not falling sounds like an issue i was having.. after re-fitting all vac lines and cleaning everything and doing a UEC it doesnt do it anymore.
if you tap the brake when its doing it (not enough to actually engage brake but just enough to get the booster working) do the revs start to drop normally?
i would say its Air idle control valve is dirty or there is a vac leak somewhere.
CodeBurn3r it does it when just rolling, say at lights when i waiting without the brakes on, i thought it might have been the booster making it struggle, but having them on or off doesn't really make a difference.
Where do i find the Air idle control valve (AICV?) and how do i clean it? alex gave me some UEC so i might run that through when i service her.
Posted 01 September 2009 - 09:38 PM
here is the IACV:
it is the brown capped thing just next to the BOV piping.
yes the upper engine cleaner will help.
i ran it thru when i first converted the car after a couple of weeks (feb) and it blew out a fair bit of crap so it may of gummed up the IACV a bit.
it does say to run another can thru if its particularly dirty...
let me know how it goes mate. both these problems could be related, also do as codeburner said and check all the vacuum lines as there might be a leak there somewhere thats causing the revs to drop.
Posted 01 September 2009 - 10:39 PM
Posted 02 September 2009 - 12:00 AM
Posted 02 September 2009 - 02:47 AM
Posted 02 September 2009 - 07:34 AM
Posted 03 September 2009 - 06:44 PM
0415 522 512
Posted 09 September 2009 - 05:42 PM
Posted 12 September 2009 - 07:26 PM
pm me your mob number, ill try work something out with the service dept, as they (we) shut at 4, but ill stay back one day if need be.Is any time good to drop in Ben? i finish work about 4..
0415 522 512
