Oil Level and Oil pressure warning light (dash)
Posted 12 October 2009 - 05:15 PM
Posted 12 October 2009 - 05:22 PM
Posted 12 October 2009 - 05:29 PM
Posted 12 October 2009 - 06:14 PM
Posted 12 October 2009 - 08:03 PM
MY07 GT-B 6MT Sedan
Posted 12 October 2009 - 09:16 PM
TBH I check my oil and water levels pretty much every day, 1st thing before I start it, takes 2 mins, it may be anal but worth it for peace of mind.
Also as stated above, changing the oil on a newly purchased car is one of the 1st things you should do... if for no other reason so you know whats in there.
Also you should be getting yr oil changed AT LEAST every 12500k... even better, half that... even better every 5000.
You can never change the oil to much in a car!
Move yr service forward to either this week or next and while there buy an extra 5lts of whatever oil their using.
Not totally anal, i check mine once a week always keep a fresh litre bottle in the boot and change it every 5000ks. And as Alex said if your low level oil warning light comes on then it is usually a little late and damage could have been done.
Posted 12 October 2009 - 11:34 PM
There isn't a "LOW level" warning light, only "low oil pressure" warning light.And as Alex said if your low level oil warning light comes on then it is usually a little late and damage could have been done.
Thanks for the tips Eric, Buddy, Buzz, & Alexxx.
Posted 13 October 2009 - 06:17 AM
same difference.There isn't a "LOW level" warning light, only "low oil pressure" warning light.
Posted 13 October 2009 - 06:33 AM
Posted 13 October 2009 - 06:36 AM
0415 522 512
Posted 13 October 2009 - 07:03 AM
Just don't use the oil light as a guide on when to top her up!
1 more thing, a while ago my mech told me that because they're a "dry sump" (meaning the crankshaft isn't sitting in oil) you can actually "overfill" them without damage. He told me that he puts about 1lt over the full mark on his wife and daughters cars.
My service manual says to put in 4ltrs. i normally put in about an extra quarter ltr and that brings it up to the full mark on the dipstick when up to running temp..
Posted 13 October 2009 - 08:52 AM
Buzz, dont take this the wrong way.
Go and smack your mechanic in the head!
"dry sump......crank not sitting in oil" WTF!!!!!!!
Subarus, like most cars, are a 'wet sump' lubrication system. Oil sits in the bottom of the sump and is drawn up into the oil pump through the pickup and fed around the engine under pressure, then returns to the sump. If the oil level falls below the pickup, its sucks air and you lose oil pressure. The crank spins above the upper most oil level.
If you over fill the oil, the counter weights and/or conrod big ends will crash into the oil and slow the crank and foam the oil. BAD. (although you can overfill safely by a small amount)
A 'dry sump' system stores the oil in a remotely mounted tank. An externally mounted pump consists typically of two or three 'scavenge' and a 'pressure' pump. The scavenge pumps are connected to either end of the sump and scavenge the oil that collects there and sends it to the tank. The pressure pump draws oil from the tank to lubricate the motor, thus ensuring reliable oil pressure under all driving conditions.
Some cars have both an oil level and oil pressure warning lamps. Toyota.
New Benz, the oil level is checked with a scan tool...Grrrrr.
Posted 13 October 2009 - 09:27 AM
Posted 13 October 2009 - 03:39 PM
Thankfully it has never come on while the engine has been running!subaru untill around 2 months ago didnt have an oil level warning light, (came in with my10 liberty)
the only way that the oil level will activate the oil pressure light is when its to late and your engine goes bang.
most subaru oil pressure switches bring the light on at under 10 psi oil pressure. so really its to little, to late.
No, but I think they do Suzuki's.is your local subaru dealer also a mazda dealer?
Posted 13 October 2009 - 04:15 PM
Posted 13 October 2009 - 10:28 PM
Posted 14 October 2009 - 12:14 AM
GEN1 Red Mica RS Liberty - Stock factory original
Love is a Legacy, Liberty, etc......
Posted 14 October 2009 - 07:23 AM
Just out of interest though, I am looking at a filtration system that allows you to NEVER change your oil, yes that's correct, never, if you don't want to anyway
Errrrr.......NO.
Dont di it.
To my understanding; filters remove the soild contaminents, not the chemical ones that are also produced when fuel is burnt.
