knocking sound
Started by camoshop, Nov 02 2009 12:47 PM
8 replies to this topic
Posted 02 November 2009 - 12:47 PM
hey guys,
Just like to get your advise on my problem, today i bought some upper engine cleaner and after i used it the car started making a knocking sound on the right hand side coming from the rocker covers , seems the buckets are making a louder sound than before , before i drive a fare distance to the mechanic just wanted to get your thoughts on what it could be , and i dont want to drive it if its something major and do more damage , i have attached a short video with the noise ,
cheers,
cam
http://smg.photobuck...nt=MOV00099.flv
Posted 02 November 2009 - 01:10 PM
Sounds like ur tappets... Sounds like my car when its cold...
Posted 02 November 2009 - 01:21 PM
It happened to mine after usin UEC. Sounds identical. It was eventually some crap from the manifold that got stuck around or near an intake valve causing it to not shut properly. It can good after about half an hour.
Posted 02 November 2009 - 01:31 PM
cheers i'll go for a drive and see if the noise goes away ,
thanks for your replies
cam,
Posted 02 November 2009 - 01:52 PM
what you doing this arvo? ill come past and have a listen
Posted 02 November 2009 - 02:23 PM
hey ty yeah i'll be home just took it for a drive and its still doing it ... so pop around if you want ..
cheers
Posted 02 November 2009 - 03:22 PM
My old liberty did this after a UEC, It went away after the oil change i did that arvo.
Posted 02 November 2009 - 03:40 PM
Sounds like the Upper engine cleaner does more bad than good!
Posted 02 November 2009 - 03:48 PM
haha seems that way from all the comments above
