First CEL
Posted 02 February 2010 - 03:11 PM
Posted 02 February 2010 - 04:03 PM
Posted 02 February 2010 - 04:32 PM
Posted 02 February 2010 - 04:50 PM
Posted 02 February 2010 - 04:51 PM
Posted 02 February 2010 - 04:54 PM
Posted 02 February 2010 - 05:16 PM
Normally (I don't see why a Subaru would be any different) the CEL will illuminate (not flashing) when the ECU detects a fault. The CEL will remain on while the fault is present and extinguish if the fault rectifies its self. The ECU will log the fault in its internal memory and it will remain there until cleared. Placing the ECU in diagnostic mode will cause the CEL to flash the stored code(s). First series of flashes represents the first digit of the code and the second set of flashes represents the second digit. This will be followed by a longer pause and the second code will commence (or the same code will be displayed 3 times before moving to the next code). If there is no code stored then the 'no code' code will be displayed using the same method of flashing.
The knock sensor constantly monitors the engine for detonation by 'listening' to the engine. If detonation is detected by the ECU, the ECU will retard ignition timing (in a series of steps) until the knock goes away. Once knock has disappeared the ECU will begin to advance the timing until knock is again detected, and so on. This allows the engine to run with close to the maximum amount of advance.
The sensor is basically a piezo crystal that generates a small voltage when it 'hears' knock.
Usually if the ECU detects a fault with the knock sensor it will revert to a 'known safe' level of advance for the particular load/speed of the engine.
If you are going to replace it, don't over tighten the mounting bolt (torque to specs) as this will damage the sensor.
Someone may wish to confirm this is the case with a Subaru as I haven't really fiddled much with them.
Hope this helps.
I wouldn't think it will log a code just with detonation, after all that what its job is.
Usually logging of a code is due to a fault with that circuit or the sensor itself. This will usually mean an 'out of range' signal being detected by the ECU.
I would do just as you suggest, clear it and see if it comes back.
....or get a lighter passenger!
Edit: Just saw Alex's post. Yes, a rattle or mechanical knock in the engine can trick the sensor.
^^^ That's the same as what my mech told me when I had a Cam sensor go... we reset it, it came back, replaced the sensor, no more light.
Posted 02 February 2010 - 05:50 PM
Posted 02 February 2010 - 06:13 PM
Beautiful thing about the knock sensor is that it needs to be anywhere on the motor.Well if it pops up again I have a spare knock sensor. Its just the hardcore spot it lives in. Well when I put the new IACV on I will have more room.
i.e. anywhere on the motor.
i.e. relocate it.
did it to Dylan's motor, and it was happy. just make sure it has a good earth. Aye Dylan?
Posted 02 February 2010 - 06:21 PM
Posted 02 February 2010 - 06:26 PM
Posted 02 February 2010 - 06:37 PM
Posted 03 February 2010 - 03:21 PM
Posted 03 February 2010 - 03:35 PM
Posted 03 February 2010 - 03:38 PM
Posted 03 February 2010 - 04:52 PM
Posted 03 February 2010 - 05:29 PM
Posted 03 February 2010 - 09:46 PM
GEN1 Red Mica RS Liberty - Stock factory original
Love is a Legacy, Liberty, etc......
Posted 05 February 2010 - 10:21 AM
