LED break light.
Posted 08 April 2010 - 10:06 PM
Posted 08 April 2010 - 11:49 PM
Posted 12 April 2010 - 08:42 PM
Posted 12 April 2010 - 09:39 PM
In the line feeding power to the center of the indicators fit a 7 ohm resistor (one each side).
Click here for more about resistors.
In the line feeding power to the rear park lights from the front of the car (before where the loom feeds the other rear park lamp) fit a diode. This acts like a one way valve so it needs to be fitted the correct way around.
Click herefor more about diodes.
Just remember that most LED globes don't meet ADR compliance and therefore are unroadworthy.
Posted 12 April 2010 - 09:50 PM
Posted 12 April 2010 - 10:08 PM
Posted 12 April 2010 - 10:30 PM
Posted 13 April 2010 - 10:52 AM
Is a break light the one that lights up when something is broken?
Ahahahhahahahahaha
Posted 14 April 2010 - 08:49 PM
Posted 14 April 2010 - 09:11 PM
Posted 14 April 2010 - 09:37 PM
Posted 14 April 2010 - 09:44 PM
The fix.The flash rate of the idicators is fast because the LEDs draw less current and the flasher unit sees this as a blown globe.
Using Ohms law, a 6.85 ohm (7 ohm is fine)resistor across each LED will restore the flash rate.
Posted 15 April 2010 - 06:01 PM
Posted 15 April 2010 - 08:05 PM
Posted 15 April 2010 - 08:08 PM
Posted 15 April 2010 - 10:41 PM
Posted 15 April 2010 - 10:49 PM
Might work.
Costs 4 times more than thediodesresistors.
Still wont fix the BRAKE problem.
EDIT: Due to being tired, overworked and underpaid.
