fuel leak when cold
Posted 22 May 2010 - 05:22 PM
Posted 22 May 2010 - 06:43 PM
Posted 22 May 2010 - 07:41 PM
Ecutek Stage 2, 3" DBE, Walbro FP, Hyperflow CAI
14.2 @ 158kph
Posted 22 May 2010 - 09:04 PM
Fuel filter is in the tank, so its not from there!
natho, I feel your pain mate. I had this exact same problem a bit under 12 months ago. (Twice) and I think it has returned in a different spot just recently too.
First time- It was the rubber fuel lines that run directly underneath the centre part of the manifold. These are fuel return lines from the drivers side fuel rail. They had perished and were leaking around the clamps. Subaru were able to access these after taking off the alternator.
Second time- Fuel leak coming from around the fuel regulator. To access that area the manifold has to be taken off. I got subaru to do this as it was above my competence level (A LOT has to be taken off to get the manifold off!) Turned out to be a busted regulator. Ended up fitting a second hand regulator as Subaru don't have access to new regulators for B4's. Also no other subaru regulator is compatible with the B4 TT engine.
As I said before, I think i have another small fuel leak again. Its once again coming from around the regulator and annoyingly, it doesn't look like the subaru mechs replaced the fuel lines leading to and from the regulator as they look very perished.
I know this doesn't paint a great picture for you, but if the fuel smell disappears when the engine is warm, then it is likely to be a minor leak as the amount of fuel escaping is being evaporated from the engine bay heat.
As alexx said- can you take a picture of the location you think the leak is coming from and we may be able to give you an idea of which line/s it could be.
sorry, i thought all models up until the 05 got the filter in the engine bay next to the strut tower!
Posted 22 May 2010 - 10:57 PM
Posted 22 May 2010 - 11:15 PM
14.2 @ 158kph
Posted 23 May 2010 - 12:12 PM
Posted 24 May 2010 - 10:23 AM
Posted 24 May 2010 - 10:50 AM
Posted 24 May 2010 - 04:46 PM
Charcoal canister!
just a thought but im pretty sure its meant to filter excess fuel from after the car is turned off and when turning it on the pressure might be pushing out the excess fuel thats sitting in the filter.
my gen1 was having a fuel smell on startup and it turned out to be the hose was loose on the canister.
it should be on the drivers side just next to the timing belt cover mounted to the side of the engine bay.
charcoal canister has the vapours from the fuel tank going through it, not fuel itself. i'm pretty sure there's a fuel leak as my fuel economy is "worse" now than it used to be, so fuel leaking is likely.
Posted 24 May 2010 - 07:43 PM
Posted 24 May 2010 - 10:55 PM
14.2 @ 158kph
Posted 29 May 2010 - 11:26 AM
Posted 29 May 2010 - 11:35 AM
Posted 29 May 2010 - 11:55 AM
Posted 29 May 2010 - 12:22 PM
14.2 @ 158kph
Posted 29 May 2010 - 12:33 PM
Posted 29 May 2010 - 04:00 PM
Posted 29 May 2010 - 06:58 PM
Posted 29 May 2010 - 07:27 PM
