2003 B4 Wont Start PLEASE HELP
Posted 20 June 2010 - 07:10 PM
Posted 20 June 2010 - 09:32 PM
Posted 21 June 2010 - 06:35 AM
Posted 21 June 2010 - 08:23 AM
The alarm is working accepts code and dash light rest of light that arent on before code and i can crank the engine so I dont think it is allarm
dont know model of import engine but the intake manifold was different so i used mine (throttle body only had two plugs mine was three)
so basically i used the long motor of the import then everything else is what i had on the car before
Havent check injector pulse yet but will do this arvo
if the inlet manifold was different then the motor is from an earlier revision car and a lot of the sensors are different. make sure you use all of yours!! you said you did the crank angle sensor, what about the cam angle sensor?
not sure if the b4 ecu gives error codes while cranking but it might be worth checking this too.
Posted 21 June 2010 - 11:09 AM
Posted 21 June 2010 - 11:52 AM
take it to a pro to get it checked out
+1 Just take it to someone if you don't know what's wrong.
There are too many variables to diagnose the problem over the net.
Will be easier and quicker.
Posted 21 June 2010 - 12:10 PM
Posted 21 June 2010 - 02:59 PM
Posted 21 June 2010 - 03:57 PM
don't forget to check the wheel/pulley that triggers the sensor.
This.
Posted 21 June 2010 - 04:00 PM
Posted 21 June 2010 - 05:54 PM
nah, my moneys on the earth FOR SURE
I will nearly bet you on that cause i have double and triple check earth
I think my moneys on the cam wheel and crank wheel being different will change them
and let yas know
Posted 22 June 2010 - 06:18 PM
Posted 22 June 2010 - 06:51 PM
