Anti Lift Kit
Posted 28 June 2010 - 08:53 AM
Posted 28 June 2010 - 12:31 PM
Posted 28 June 2010 - 01:36 PM
Posted 29 June 2010 - 04:21 PM
Posted 29 June 2010 - 05:07 PM
Posted 29 June 2010 - 05:14 PM
fpDropping the X member?
I did mine myself. its pretty straight forward, but if you dont have the tools/time then Id say $150 inc alignment saves you some possible headaches.
i just rang wholesale (my contact wasnt there) n they are all booked out 4 this week n im going away next weekend n i have 2 work all next week...
its says on the instruction sheet
"vehicles with manual trans, 4 ease of removal n fitment, remove gearbox x-member"
Ive got all the tools 2 do the job just dont wanna get stuck while doing it... I'll ask my bro n my uncle n see wat they think..
Posted 29 June 2010 - 06:41 PM
MY07 GT-B 6MT Sedan
Posted 29 June 2010 - 07:09 PM
gearbox crossmember was sort of in the way on my car, you can work around it (i did). it gets in the way with removing the bolts through the chassis. but if you had the car on a hoist to do it would be a piece of piss!
Posted 29 June 2010 - 07:15 PM
Posted 29 June 2010 - 07:25 PM
If i cant get some place to install them ill take it down to my uncles old workshop, the new owneers owe me a few favours lol
I can chuck it on the hoist n do my oil change service while I can get him to chuck on the ALK...
Btw should i change my oil to 5W-30 since im goin to the snow next week? Im currently using Nulon 10W-30 Hi-Tech Fast Flowing Engine Oil.
Lately its been a bit noisy/tappy on start up since these colder mornings.
you don't need to change oil. i'm running a 10w60 and its no different. just make sure you let the car warm up properly... doesn't mean you let the car idle for 5+min either..
Posted 30 June 2010 - 08:54 AM
Posted 03 July 2010 - 03:07 PM
We werent sure how much caster to dial in so we just went with a bit higher than stock.
(stock = 3.08 -/+0.75)
Here are the specs of before and after.
Apparently the caster on left is suppose to be higher than the right to stop it from pulling left but when I was driving home it was pulling at all...
Anyone that has an ALK in there cars what do you have dialled in?
Posted 03 July 2010 - 03:56 PM
Posted 04 July 2010 - 11:03 AM
Posted 04 July 2010 - 11:28 AM
i read on whiteline site that these kit are designed to add 0.5 degree
Already know that part but Im trying to figure out wats the optimal setting...
I think when I get back from the snow, i'll go to Wholesale suspension and get them to adjust it to max caster
Posted 04 July 2010 - 12:10 PM
it is a fixed castor adjustment, the only adjustment so to speak you have is the positioning of the ALK as far forwards as possible.
Posted 04 July 2010 - 04:32 PM
Thats it, you can only go as far as the elongated holes allow you too.
I did it by "carefully" using the car jack to push on my brake caliper towards the front of the car,with the base seated on the lower part of the wheel arch,its only a small movement so dont go so far that your bending the arch.
When the ALK cant move anymore tighten the two bolts up and thatll be the Max castor available for the kit.
Edit: This is the thread i got the info from
http://www.rexnet.co...=109631&hl=free
Matt
