H6 Engine
Posted 11 September 2008 - 04:14 PM
former - 2000, Gen 3 - 2.5l RX Liberty, mods - Powerchip Gold 98, Borla extractors, Cat-back sports exhaust, Bilstein Suspension w/ Kings low's, Whiteline X\Heavy duty ADJ rear swaybar, Whiteline front Strut Brace, 6000k HID Xenons.
#2 Guest_SubaruJunkie_*
Posted 11 September 2008 - 06:02 PM
Posted 11 September 2008 - 06:39 PM
Posted 11 September 2008 - 07:58 PM
#5 Guest_SubaruJunkie_*
Posted 15 September 2008 - 09:21 PM
Posted 15 September 2008 - 10:40 PM
Posted 22 September 2008 - 02:26 PM
Posted 22 September 2008 - 02:28 PM
Posted 22 September 2008 - 03:47 PM
Engine specifications EZ30 Type: flat-6, aluminum block and heads
Bore x stroke: 3.51 x 3.15 in, 89.2 x 80.0 mm
Displacement: 183 cu in, 3000 cc
Compression ratio: 10.7:1
Fuel-delivery system: port injection
Valve gear: chain-driven double overhead cams, 4 valves per cylinder, hydraulic lifters, variable intake- and exhaust-valve timing and lift
Power (SAE net): 256 bhp (191 kW) @ 6000 rpm
Torque (SAE net): 247 lb·ft (335 N·m) @ 4400 rpm
Redline: 7000 rpm
Edit:
This attachment will help ya, Matt.
ez30rspecsli1.jpg 194.38KB 17 downloads
Edited by Dylan, 22 September 2008 - 03:50 PM.
Added attachment.
Posted 22 September 2008 - 03:56 PM
