Hot air coming out of air vents?
Posted 07 December 2010 - 09:55 PM
Any ideas as to what the issue could be?
Posted 07 December 2010 - 11:06 PM
Posted 08 December 2010 - 08:01 AM
While it's off you can also press the "inside only air" button, and then you won't get any air coming through at all.
Posted 08 December 2010 - 11:57 AM
Walts - I wouldn't have had the air-con set to 28 for at least a couple of weeks as its been really humid here even with the rain. And besides, this shouldn't happen should it? My Gen2 never did it. I'll try what you said though ~ thanks.
Posted 08 December 2010 - 01:04 PM
I had the same aircon as you in the Gen 2, and now still have the same aircon as you haha.
The Gen 3 A/C is a weird system, very different from the Gen 2. No matter where you have the vents set, it always seems to come out of the face vents as well.
Posted 08 December 2010 - 01:31 PM
Posted 08 December 2010 - 06:06 PM
Posted 08 December 2010 - 06:12 PM
I'll have the mechanic look at it when I send it there to have the tensioner looked at. Thanks for the advise guys, just wanted some preliminary ideas.
Stupid Gen3's
Posted 08 December 2010 - 11:14 PM
All my Subaru's have done this. I made a thread about it.
Nik
Posted 08 December 2010 - 11:35 PM
Posted 09 December 2010 - 07:23 AM
Just checked mine.
No air bleeding from the face vents at all.
Will blow some hot air if the car has been sitting in the sun, other than that it seems fine.
Posted 09 December 2010 - 07:50 AM
Just checked mine.
fork.
Must be just mine.
If I have it set of defog, it goes on defog and face.
If I have it set of feet, it goes on feet and face.
If I have it set on feet and face, it goes on feet and face but slightly more on face.
etc.
How the feck do I fix that? Not that it's a major issue.
Posted 09 December 2010 - 07:51 AM
Posted 09 December 2010 - 07:58 AM
Everything's just attracted to it?Must be your face.
P.S. is that the only non-technical piece of advice you have ever given? (OTHER than IN the GT)
Posted 09 December 2010 - 08:01 AM
(other than in the GT)Everything's just attracted to it?
P.S. is that the only non-technical piece of advice you have ever given? (either than on the GT)
Posted 09 December 2010 - 08:03 AM
Shudup
It's early.
Posted 09 December 2010 - 08:05 AM
Its a fault in the ventilation system.
Posted 09 December 2010 - 08:08 AM
Sounds like maybe the solenoid on your air diverter flaps is not engaging properly?
but to fix it is too much work so just put up with it lol
until it breaks and makes a horrible sound like mine is... then you can swap back to a gen2 and enjoy the good life
Your face is the fault of a ventilation system.
