Transmission oil coolers.
Started by Soop, Sep 13 2008 04:09 PM
7 replies to this topic
Posted 13 September 2008 - 04:09 PM
Hey guys.
Looking for some information regarding the installation of an oil cooler.
I've located the lines running from the gearbox to the radiator. But I am unsure of the correct/most efficient way to go about plumbing in the new cooler.
On other car's I have seen, the cooler is run in parallel with the radiator to cool the transmission fluid. This is what i wish to achieve with my own car.
What have some of you done with your instillation?
Kosti, have you done something similar?
TSM
Posted 13 September 2008 - 04:24 PM
Bloody Database!
What I primarily need to know is, which is the hot line and which is the cold line from the radiator?
I want to intercept the cold line from the radiator and run it to the external cooler then back to the transmission.
TSM
Posted 13 September 2008 - 06:45 PM
i dont know for sure, but logically the top will be the hot one mate.
0415 522 512
Posted 13 September 2008 - 06:58 PM
Cheers.
I didn't even want to guess with this.
I'll have another squiz tomorrow.
TSM
Posted 14 September 2008 - 08:52 AM
I have a trans cooler on mine Paul. I can get a couple of shots up for you, or at least the connnections.
Posted 14 September 2008 - 10:39 AM
Heres one I prepared earlier.
The trans line coming to the bottom of the radiator you leave, You just basically put the transcooler in the trans line before the top radiator connection.
Posted 14 September 2008 - 10:48 AM
Wont let me edit??
Heres how mines mounted.
Posted 14 September 2008 - 11:46 AM
Cheers mark. I'll hook it up today.
TSM
