I currently have a Gen 2 Liberty (fwd) and auto unfortunatly, so when it comes time to do a turbo conversion i want it awd and i have all the gear from a Gen 1 auto awd Liberty and wondering if its interchangeable or should i just get find the parts of a wrecked Gen 2? And i also intend to still run the auto box when the turbo conversion is done only because the partner can't drive manuals and do you have to find a half cut that has a auto in it or just find the auto ecm.
Any information will be appreciated
Thanks
Damien
Gen 2 and Gen 1 running gear
Started by Damien, Dec 23 2010 08:37 PM
2 replies to this topic
Posted 23 December 2010 - 08:37 PM
Posted 23 December 2010 - 09:18 PM
when you get your half cut get the whole rear end as well. you should get the rear drive shafts, tail shaft and diff with the cut already
Posted 23 December 2010 - 09:21 PM
ok thanks and im looking at a forester cut or should i find a wrx cutwhen you get your half cut get the whole rear end as well. you should get the rear drive shafts, tail shaft and diff with the cut already
