Will these headers fit on my RX?
Posted 19 March 2011 - 03:34 PM
And I'm wondering if they'll fit my car which is a 97 subaru liberty RX, I know that the general shape will fit they're the correct type, but just want to know if the bolt holes from centre to centre will be the same because the headers are for a turbo engine and mine is not.
any help will be appreciated
Posted 19 March 2011 - 04:48 PM
from what i can tell, looking at my mates auto one, the header design bolts up how a turbo manifold would, with the rest of the exhaust starting where a turbo up-pipe would be. Im soon going to fit them on and see what happens, if it works you'll get the turbo rumble!
Posted 19 March 2011 - 04:54 PM
Posted 19 March 2011 - 05:06 PM
The money you spend doing headers would probably get you at least a front and rear swaybar or even 4 pot brakes with rotors.
Posted 19 March 2011 - 06:17 PM
Only modification needed is for a new thread for the o2 sensor.
Posted 19 March 2011 - 06:20 PM
Posted 20 March 2011 - 07:57 AM
Posted 20 March 2011 - 08:24 AM
Posted 20 March 2011 - 11:37 AM
Posted 20 March 2011 - 09:34 PM
Every Gen2 RX i've seen has WRX style manifolds with a silly up pipe going over the Xmember.
Posted 20 March 2011 - 10:53 PM
Yeh I was thinking the same thing. They're uneven.How are RX headers even length?
They sound pretty great with the Rexy headers though (weren't they the Borala replicas that came on eBay many years ago?).
Posted 20 March 2011 - 11:25 PM
The 2 banks converge at a central point in the manifold before mating up with the up pipe bit. They were designed to neutralise the boxer burble.
Posted 20 March 2011 - 11:30 PM
Posted 20 March 2011 - 11:32 PM
Those eBay headers you are thinking of were for all na gen 1, 2 and 3 bar the 2.5 dohc. The 2.5 dohc uses a turbo crossmember so those headers won't fit to the gen2 2.5.
Posted 20 March 2011 - 11:36 PM
Ah yes, I stand corrected. How could I forget - they fit everything but the Gen2 2.5L...Those eBay headers you are thinking of were for all na gen 1, 2 and 3 bar the 2.5 dohc. The 2.5 dohc uses a turbo crossmember so those headers won't fit to the gen2 2.5.
got put those on, pulled out the noodle that goes over the crossmember and just had it mated up with the centre pipe like a normal exhaust would go
Posted 21 March 2011 - 08:19 AM
They're not designed to neutralise the "boxer rumble". They're not even length. They're just not drastically un-even.
All they're designed to do, is take the exhaust gas from the engine to the rear of the car, they not even requiered to do it in a very efficient manner.
Using a turbo manifold is going to be fraught with fail. Make sure the Primaries aren't too big. I'd bet they are though.
NA and Turbo exhausts work very differently. You can't use a turbo manifold effectivly in an NA application.
