Sound System for a Liberty
Posted 02 July 2011 - 12:53 AM
I finally got around to getting my P's after having my car for 2 months meow (for anyone who recognises it, I'm Jordan's brother).
I'm driving a Subaru Liberty 2.5 Rx Gen 3 which is in perfect mechanical condition. I bought it for $7,500 with ¬120,000 k's...
The only problem I've had with it was that the rear left speaker always sounded a bit shotty whenever I put the volume up, which I tend to love doing...
I eventually decided to pull the door apart and found that the speaker was more than a little bit broken, it was completely torn and blown out. I took it out and went down to Supercheap, repco and a bunch of wreckers looking for a replacement, but no-one can get their hands on an identical one, so I've decided I may aswell go all out and put in a whole new speaker system.
Problem is though that I don't really know all that much about what I'm doing. The speaker I took out is a Clarion 6'' 4ohm, 15V nominal with a 6.5'' triangle fitting (the standard speaker for the car).
I want to replace it with something that will be loud and bassy, but I have a budget of about $200. I'm replacing the headdeck that came with the car with a Sony BT3300U.
Could install most speakers that have a 6.5'' triangle fitting on my own, but anything that needs a proper fitting I'm going to need to get professionally installed (or a rediculously good guide).
Need to replace the 4 door speakers, and don't know if I need to change the crossovers and tweeters (don't know the difference between crossovers and I don't know why I need to change the tweeters if they work properly).
Any suggestions for speakers or installation processes is more than appreciated.
Any help, tips or suggestions are also very appreciated.
Posted 02 July 2011 - 01:00 AM
There's a new DIY section, might find something useful there.
There was thread regarding sound system suggestions not loooong back, a lot of info and brands/speakers thrown up there.
Like I said, search like a mofo, it might take some time but all your questions have been answered on here before, and in great detail.
Jordan selling drugs to buy a STi yet? If not tell him to hurry it up.
edit: found this; http://www.subyclub....__fromsearch__1
Posted 02 July 2011 - 10:44 AM
Posted 02 July 2011 - 11:35 AM
for $25 a pill it better be good panadolYes I am Duke, want some panadol?
Posted 02 July 2011 - 12:27 PM
Posted 02 July 2011 - 04:19 PM
But Since one of yours is broken I'd just take your speaker in to your local Jb or car audio joint and say you want a speaker to go where this one went and want to spend upto $200. They'll be able to fix you up with something pretty good infact you probably wont need to spend much more then $100
Posted 03 July 2011 - 04:18 PM
Also, I'll sell the panadols for $20 a piece, just nick them from his room and he'll never notice...
Posted 03 July 2011 - 04:25 PM
The new unit won't put a higher voltage into the speakers, it'll put my wattage
As I stated the stock speakers run fine on an aftermarket headunit.They actually run really good. The stock speakers are made by clarion. So their pretty decent.
Posted 03 July 2011 - 04:51 PM
Looks like I have my project for tomorrow...
Posted 03 July 2011 - 05:00 PM
Posted 03 July 2011 - 06:11 PM
The base is 100x more clearer as the bass is in the cabin, not the boot, plus it's an expensive 6x9.
There is a 6x9 cutout in the metal on the parcel shelf, all you need to do is cut the carpet out and it fits in snug!
It's a clean way to save space and have good, cheap base.
