coolant leak
Posted 07 August 2011 - 04:46 PM
the radiator doesnt leak, or the water pump, or the header tank. the coolant drips under the car into the driverside extractor heat shield and oil filter hose.
are there any hoses that run under the manifold or close by that may be the problem....or even a cracked block????can this happen???
thanks again fellas
Nick
#2 Guest_Jesse_*
Posted 07 August 2011 - 05:32 PM
Is there any coolant on the underside of the oil filler cap? Hope it's not a blown head gasket.
Good luck getting it sorted.
Posted 07 August 2011 - 08:16 PM
Posted 07 August 2011 - 09:47 PM
Posted 07 August 2011 - 10:04 PM
can the car be run without tmic?
Posted 08 August 2011 - 05:14 PM
the tiny little hose that goes into the oil filter, streams out once its at opperation temp onto the headers
thanks fellas
Nick
Posted 29 May 2012 - 03:22 PM
I have a closed deck EJ20T in my Gen 2, and also have some coolant dripping onto the driver side exhaust at running temp. It's been doing my head in for a couple of weeks now as it steams a little when parked at the lights, but when I get to work, and open the bonnet it stops so I cant trace it!!
Will check the oil fiter hose.
*Edit* Didn't realise this thread was so old. Sorry for the epic thread dig... As you were, nothing to see here...
Posted 29 May 2012 - 08:28 PM
At least you searched before starting another thread.
Take a good look when its cold. Coolant will often leave a stain that can be traced.
Posted 29 May 2012 - 10:25 PM
Posted 30 May 2012 - 09:20 PM
Alex had a leak in a very similar location.I just so happen to have one at the moment also...... But mine is on the passenger side above the steering rack. Seems to be coming from the engine block..........
It was one of the pipes that fed the heater core.
I suggest that as a start point for any leak on the passenger side.
