Starter Motor Noise
Posted 15 August 2011 - 12:04 PM
As of saturday morning, my car(TT B4) has been making a weird noise when starting. It isnt taking any longer or shorter when kicking over but after the engine has started it makes a noise(which to me sounds like the starter motor isnt disengaging straight away as its like i've continued trying to start it, but its not so loud) and it does this for about 1-3 seconds then it stops and everything is fine...i hope...It also does this regardless of being cold or warm/hot.
Has anyone come across this problem, or have an idea as to what it could possibly be as it has me worried(though any unusal noise gets me worried lol)
Thanks
Posted 15 August 2011 - 12:09 PM
#3 Guest_Jesse_*
Posted 15 August 2011 - 02:28 PM
This is on a gen 2 TT so it may be a different set up on the B4's.
Good luck getting it sorted
Posted 15 August 2011 - 05:26 PM
Yep can do Walts, ill get on it when i finish work tonight.Maybe post a video of the noise mate, is that's possible? It will definitely help with the diagnosis.
Hey Jesse, hmm might be a possiblity.....but it does it from cold in the morning and still does it after its all warmed up...Hey mate, I get a similar thing with my car sometimes. Miles from AM Auto said that it's caused by the bushes in the starter motor getting too hot because they are so close to the secondary (?) turbo.
But thanks hopeuflly nothing to bad lol.
#5 Guest_Jesse_*
Posted 15 August 2011 - 05:28 PM
I quite often get the starter motor just clicking a few times and then it cranks.
Posted 15 August 2011 - 06:51 PM
#7 Guest_Jesse_*
Posted 15 August 2011 - 06:55 PM
Posted 15 August 2011 - 08:10 PM
Maybe it was what Jovi was saying, and it must have fixed itself....
Either way thanks all for helping out
Posted 15 August 2011 - 09:46 PM
Pull starter motor off.
Pull apart the starter solenoid, clean it up with petrol. There'll be a shedload of dust/carbon/clutch friction material.
I also went over the contacts with a wire brush, and cleaned them up.
I didn't bother pulling apart the motor itself.
I marinated both the motor and the starter in inox (that stuff is gold. buy some!)
Left it to drip dry, bolted back it in, and has been gold since. I can even hear it starting cleaner and stronger, and with less turns.
Posted 15 August 2011 - 09:50 PM
sooooo, i left for work and it made the noise when starting again, plus a bunch of times before that, I get home get the camera out set it all up to record, and wow...my car has stage fright, the noise has completely stopped I guess thats a good thing, though could it also be a bad thing....
Could have just cleared a path for its self, but best is get it cleaned or if you want to pull it down take apart and clean same some moeny...the only thing that does go wrong with Subaru starters is brushes get worn over time and when it start to click people push it to far and burn the starter very rare that the bushes go but then it grinds really bad...
Keep us posted how you go.
Posted 16 August 2011 - 07:35 PM
Hmmm so anyway looks like i've just found something useful to do this weekend instead of drinking, though i do have a few questions as to how difficult it is to pull the starter motor off/out. I'm pretty confident with doing things though ive never actually done it before so any helpfull tips would be much appreciated
Thanks
Edit: Not sure if it helps in any way but just a reference i have 75k km's on it.
