Help: Keyless Entry Flash+Sound
Posted 22 August 2011 - 05:39 PM
http://www.subyclub....__fromsearch__1
Which I plan on doing when i get a day off...
But is it possible to have it make a sound (beeping) When it locks/unlocks (like most people had at Morgans) Without buying a whole new alarm or keyless entry system?
Any help would be appreciated,
-Jordan.
Posted 22 August 2011 - 06:33 PM
Posted 22 August 2011 - 06:38 PM
Posted 22 August 2011 - 06:47 PM
I need to know where that harness is in my Sedan.
Posted 22 August 2011 - 06:50 PM
Posted 22 August 2011 - 06:57 PM
I remember you pointing to something in your engine bay and saying its the alarm beeper i think.
Posted 22 August 2011 - 07:16 PM
I think 1 relay should be able to handle the current of all the indicators, it only switches on for a very brief time.
Posted 22 August 2011 - 07:44 PM
You can wire it into your tailgate lock or door lock actuator with a Piezo buzzer from jaycar http://www.jaycar.co...w.asp?ID=AB3456
Only problem is u can only have it on either lock or unlock.
Posted 22 August 2011 - 08:01 PM
Posted 22 August 2011 - 08:14 PM
Do you have one Nick?
Yeah I've got a siren from my immobiliser. That's a whole different thing Jordy.
Posted 22 August 2011 - 08:28 PM
It's not very loud though and I'd love for some of you guys to show me a louder beeper rather than the quiet piezo beeper.
Posted 22 August 2011 - 08:39 PM
In my keyless entry module there were 2 spare relays which I hooked up to the LH and RH indicators. Instead you could probably get away with hooking up both LH and RH indicators to one relay, leaving the second spare to power a buzzer.
I think ill try do this, cause the one in that manual the guy has a mp3 of it and its just a long beep, i'd rather make it do the beep beep and beep that is similar to the length of the flashes from the indicators. Would having the piezo in under the dash near the unit be a problem, loud from inside I spose, though unless you are physically challenged or dosing on some strong **** i don't think you will be locking your car while you're in it.
