Camber problems
Posted 25 August 2011 - 08:50 AM
Just came back from getting wheel alignment n have a problem with the right front camber... The guy said it can either be my strut, hub or bolts... Can anyone shed some light?
Posted 25 August 2011 - 08:59 AM
Posted 25 August 2011 - 09:36 AM
I don't mean to sound like a mean captain obvious, but he has told you where the problem most likely lies. You will need to address that, maybe start simple by replacing the camber bolt.
Someone on OzFoz suggested strut tops... I know I'm using a WRX n a Foz, can't remember which side is wat though...
When I get back from the snow I'll get some whiteline camber bolts n replace both sides n replace the WRX strut top with the Foz one
Posted 25 August 2011 - 09:44 AM
I think you have had your share of bad luck thus far.
Posted 25 August 2011 - 09:47 AM
Nice nice hopefully for you bro it is a nice simple fix
Tell me about it... Lol
Btw isnt -2 camber a good setup?
Posted 25 August 2011 - 09:54 AM
Posted 25 August 2011 - 09:57 AM
Posted 25 August 2011 - 10:00 AM
I'd be more concerned at why the LH is only -0.5.
For the camber bolts, you don't replace the O.E ones, you put them in the lower hole.
Posted 25 August 2011 - 10:22 AM
The strut tops were both the same weren't they?
Yeh tops r the same but the bearings in WRX ones were a bit worn..
Posted 25 August 2011 - 10:30 AM
-2 is nothing, just get the toe to 0.00 and you'll be fine.
So what should I be correcting?
I just had a quick look at the struts from under the bonnet I don't the the strut tops are sitting correctly...
Left side
Right side
The two little rubber bits are not at the same angle left and right so that may be the problem...
Posted 25 August 2011 - 10:51 AM
Posted 25 August 2011 - 10:52 AM
It's not like the rear where they have the arrow and say on them "Outside".
I'd say either the bolts aren't done right, something is bent or a strut is stuffed.
Posted 25 August 2011 - 10:53 AM
That would suck.something is bent or a strut is stuffed.
Posted 25 August 2011 - 01:09 PM
That would suck.
If they are I do have my Boge struts from lib I can use
Posted 25 August 2011 - 10:01 PM
Posted 25 August 2011 - 10:27 PM
He has done a 'toe and go' alignment. If he had tried to reduce the RH camber he would know if it were the bolts.
Forget the after market camber bolts.
I had them 'for about an hour' and took them out as they gave me too much neg camber. With the std bolts I have -1.5deg camber, which will give a bit more grip without chopping the tyres.
Have the front end checked out to correctly diagnose the issue, before parts are replaced at random.
Posted 26 August 2011 - 08:25 AM
Posted 29 August 2011 - 11:05 AM
Second mistake was asking the internets to guess.
Are all your bushes in good condition?
Do the standard bolts have an elliptical shaft/thread?
Personally -2deg negative camber isn't excessive. So long as its the same on both sides, I wouldn't be loosing sleep over it.
