Posted 09 October 2011 - 04:33 PM
Sine there is heaps on the market and the prices are different and brands.
Any of them fail or just dont flow etc...
cheers
Posted 09 October 2011 - 04:52 PM
Posted 09 October 2011 - 04:54 PM
Posted 09 October 2011 - 04:57 PM
Is the FPR redundant whence a fuel pump is not up to the flow?
Nik
Posted 09 October 2011 - 04:58 PM
Luke that could be a choice for shiny or color but i rather have good and dont care about shiny or color but not pay stupid amounts...
skillionaire - the reason im doing it is the stock FPR has destroyed my high flow pump, so it has to go and since its going the logical choice is to do a parallel fuel line at the same time...
Posted 09 October 2011 - 05:15 PM
So it has restricted flow which has created impeller back pressure onto the FPR? I'm confused. I was under the impression that an FPR is defined in usage by the rate/flow of which the pump can create.
Are you saying your FPR is not able to 'flow' what your uprated fuel pump is capable of?
Nik
Posted 09 October 2011 - 05:44 PM
The car i want to do the parallel fuel line mod on is stock with a high flow pump also which has been killed, it does not deliver fuel when engine is in high rpm(but its beside the point)
the cracked gage sard FPR is on a total diff car....
Posted 09 October 2011 - 06:15 PM
Slower Then The Rest
50.CYA
YAMAHA R3 2015
Posted 09 October 2011 - 06:26 PM
http://www.turbosmar...index.php?id=38
http://www.turbosmar...index.php?id=35
does the job
Posted 09 October 2011 - 06:33 PM
What is confusing you Nik? I'm asking which one people use?
Hi,
I am confused as to why the FPR is the cause of a fuel pump failure.
Nik
Posted 09 October 2011 - 06:39 PM
Posted 09 October 2011 - 06:40 PM
+1
Hi,
Nik
Posted 09 October 2011 - 06:42 PM
+2
Hi,
Nik
It hasnt affected mine at all?
Posted 09 October 2011 - 06:48 PM
On a serious note.
+3
Posted 09 October 2011 - 07:07 PM
But for the confused ones who looked way to far in to it must be hard to say my car is stock, or i have this brand FPR
Posted 09 October 2011 - 07:28 PM
Hi,
Nik
Posted 09 October 2011 - 10:31 PM
If this is the case, which I am not too sure that it would be (just my opinion) than you should let others know before they too are subjected to fuel pump failure by murderous FPR's.
Posted 10 October 2011 - 12:17 PM
Posted 10 October 2011 - 01:16 PM
As someone who is allegedly an "expert" in this field, I await your "expert" opinion.
Posted 11 October 2011 - 08:20 AM
Check your wiring to the pump or how the pump sits in the bracket.
