MAF sensor cleaning.
Posted 11 October 2011 - 10:14 AM
Im just about to do a bit of a service on the car and thought id give the MAF sensor a bit of a clean as well, but i wasnt sure what to use. I read that you use either proper maf cleaner though you could also use electrical contact cleaner. I have plenty of this stuff http://www.jaycar.co...w.asp?ID=NA1012 but thought i'd make sure it should be right to use before i go spraying it all about...
Thanks
Posted 11 October 2011 - 10:17 AM
Posted 11 October 2011 - 10:42 AM
Posted 11 October 2011 - 12:16 PM
I use Brake Cleaner.
Shazza
Posted 11 October 2011 - 02:12 PM
I don't like that part about it lubricating. I use a sensor cleaner and have in the past used an electrical contact cleaner, but that contact cleaner did not have any form of lubricant in it.
thanks for the help guysYeah you don't want a lubricant, it'll be insulating the element from any actual airflow, which is the opposite of what you want.
yeah i seen the part that said contact cleaner and lube...but wasn't to sure but you guys have confirmed it for me.
Cool well i need some of that stuff anyway so might have a go using it.Whatever you're planning on using, spray it on a steel bench first. Blow it off with the airgun. The one that doesn't leave an oily residue is what you should use.
Thanks everyone
