Auto Transmission Lock?
Posted 15 November 2011 - 09:38 PM
Will this help me at all? since i can only get it to rev upto 2500 before i take off.
And if so is it mechanical or electronic ?
Posted 15 November 2011 - 10:09 PM
These will cause the transmission to select two gears at the same time thus locking it solid. This allows the engine to be held at full throttle to run the engine speed up to the coupling point (stall speed) of the torque converter without the use of the brakes allowing the car to leave the line at maximum grunt. This also prevents the front tyres skidding over the start line.
When the tree goes green, flick the switch and hang on.
Only really needed for big torque drag cars running hi-stall converters.
Posted 15 November 2011 - 10:25 PM
You will kill your trans.
Posted 15 November 2011 - 10:48 PM
Do you mean a trans brake?
thats it trans brake...
Don't bother.
Posted 15 November 2011 - 10:51 PM
Posted 16 November 2011 - 06:54 AM
Posted 16 November 2011 - 09:49 AM
Move into D on green.
Win.
Or lose.
Posted 16 November 2011 - 10:02 AM
And hopefully a gearbox so you can buy a manual box and do some real drag racingA great way to blow a front diff tsg.
Posted 16 November 2011 - 04:02 PM
Fixed that for you.And hopefully a gearbox/engine so you can buy a better car and do some real drag racing
Posted 17 November 2011 - 10:33 AM
lol, well I didn't say it was a good idea.
Fixed that for you.
Thanks i think... Although I do still think the B4 is pretty good, had plenty of fun in mine
I even miss the TT lag sometimes
Posted 17 November 2011 - 02:54 PM
I love the secondary kick someone needs to make a 3ltr twin turbo, with the newer technology it'd be a beast.
Posted 20 November 2011 - 08:31 AM
I would probably recommend a dedicated trans cooler, and you need to do more regular fluid changes if you drive it in this manner
Posted 20 November 2011 - 10:55 AM
Someone hasI love the secondary kick someone needs to make a 3ltr twin turbo, with the newer technology it'd be a beast.
http://www.pulseraci...6Liberty.htm
