Diff oil level...
Posted 06 January 2012 - 05:42 PM
When I first pulled it was on the L marker, when cleaned and put back in, barely on the dipstick. It was a clear substance, I am not real familiar with diff fluids. Car was cold by this point.
Also is there another location I should check the levels, I assume there is a rear one? How should I go about sorting it out?
Posted 06 January 2012 - 06:04 PM
on the rear just take out the top filler plug (the lower is the drain plug) on the back of the diff to check the fluid. when full the fluid will come up level with the filler plug.
Posted 06 January 2012 - 06:11 PM
Posted 06 January 2012 - 09:14 PM
Your front diff needs a top up if so. Hot/cold doesnt matter, its not power steering fluid.
Diff fluid is a semi clear, yellowish fluid so on a dipstick will appear clear to some extent.
Posted 06 January 2012 - 10:06 PM
Can I just top it up? What with?
Posted 07 January 2012 - 06:56 AM
I use multitraxEh... not really now that I think about it, the driveway is sloped. I might bring it into the garage tomorrow and check again.
Posted 07 January 2012 - 07:55 AM
Personally I'd drain it and use new oil.
