V2 RA STi 5 Speed
Posted 18 April 2012 - 01:39 PM
Whats involved in putting this box in my car? DCCD Controller would be needed? plus 3.9 diff.
would that make cruising in 5th a higher RPM?
Tell me things about these boxes Puhlease!
Posted 18 April 2012 - 01:43 PM
Aren't they 4.11 ratio Adamantium?
mdsc
Shazza
Posted 18 April 2012 - 01:44 PM
Item 1: V2 STI type RA Gearbox (with gearbox mount and 5spd crossmember): JDM Impreza WRX STi RA MY95 TY752VB3EA 3.454 2.333 1.750 1.354 0.972 3.416 1.000 3.900 DCCD (35:65) Open - details from 'The SPDA Transmission Chart'
Posted 18 April 2012 - 01:46 PM
Posted 18 April 2012 - 01:49 PM
Thanks Cam. That counts it out!
Posted 18 April 2012 - 02:01 PM
3500rpm at 100km/h i think alexxx said petescar does
That seems more 4.11 or 4.44 territory to me.
I would have assumed that 3.9 would sit at a lower RPM at that speed.
Posted 18 April 2012 - 02:08 PM
Posted 18 April 2012 - 02:12 PM
Posted 18 April 2012 - 02:13 PM
Posted 18 April 2012 - 02:21 PM
Posted 18 April 2012 - 03:42 PM
Oh, and no dccd controller will revert the box to max rear torque transfer - ie 35 front 65 rear. Although werent the early boxes 30:70? or did the later models go to a 40/60 split? I know they changed them after about 04-05 I think.
Ben
Posted 18 April 2012 - 04:07 PM
Googling, gearbox code says 3.9
so are you sure it's a V2?
Posted 18 April 2012 - 04:12 PM
Looks like its from a 95 RA.
Posted 18 April 2012 - 04:14 PM
Posted 18 April 2012 - 04:25 PM
V2 STi RA = 3.9, most often DCCD, most often with a plated rear diff. It is a close-ratio box that sits ~3500 @100km/h from memory (I put a V2 STi RA drivetrain under my grey RS). Has a super-weak keyway in 5th gear (easy to shear, almost impossible to replace).
V2 WRX RA = 4.11, most often NON-DCCD, and is even closer ratio than the STi RA 'box and will sit +4000rpm @ 100km/h (from memory).
I thought V2 Type RA was 4.11 final drive. V1 Type RA was 3.9. The later model GC8 STI's went to 4.44
V1/V2 are pretty much the same thing, Aek. STi RA is 3.9, WRX RA is 4.11.
V3-V6 are 4.44, but some STi RAs could be optioned with 3.9s.
Ben
Pre 2006 ALL DCCD centre diffs are 35:65 split, 06 on are 49:51 among a host of other revisions (extra synchros, refined ratios, etc)
Also, it's not torque-split as such. Common DCCD misconception.
Posted 18 April 2012 - 04:34 PM
Posted 18 April 2012 - 04:36 PM
Don't buy one of these boxes if you do a lot of highway km, though. Not only did my car get raped on fuel with this set-up (on boost @110 FTL) the box apparently doesn't like the high constant speed and will wear quickly.
Posted 18 April 2012 - 04:38 PM
FYI my 5 speed is 4.44 and revs 2800rpm @ 100kph... all wrx post 06 are similar to this.
Posted 18 April 2012 - 04:39 PM
